I don't know about CEXP -- Ernest will have to check with Till on this.
I did try running the tests on a couple of platforms here. Looks like
RTEMS handles the C++ destructors properly.
uC5282 -- has a few flaws in the corners of the floating point support
routines:
not ok 259 - -Inf * NaN
# Expected result is nan, actually got inf
Literal: inf
UNARY_NEG
Literal: nan
MULT
ok 260 - NaN * 0.0
not ok 261 - NaN * Inf
# Expected result is -inf, actually got nan <<<<<< Interesting --
the CALC is right and the C code is wrong!
Literal: nan
Literal: inf
MULT
not ok 311 - -Inf / 1.0
# Expected result is -inf, actually got inf
Literal: inf
UNARY_NEG
Literal: 1
DIV
***** epicsAlgorithm *****
1..22
ok 1 - epicsMin(f1, f2)
ok 2 - epicsMin(f1, -Inf)
not ok 3 - epicsMin(f1, NaN)
ok 4 - epicsMin(f1, Inf)
EPICS Test Harness Results
Failing Program Tests Faults
epicsAlgorithm 22 4
epicsCalcTest 533 3
Failed 2/20 test programs. 7/1587 subtests failed.
Programs=20, Tests=1587, 597 wallclock secs
<<<<<< Interesting -- the CALC is right and the C code is wrong!
mvme3100 -- looks good
All tests successful.
Programs=20, Tests=1587, 458 wallclock secs
On Sep 17, 2008, at 9:54 AM, Andrew Johnson wrote:
Hi Ernest,
On Wednesday 17 September 2008 00:01:58 Ernest L. Williams Jr. wrote:
Target: MVME3100
OS: vxWorks 6.6
EPICS: base-R3-14-10-pre1
Looks like, I failed on an exception.
The libCom tests are meant to be a standalone program run in a
system without
an IOC running. Please boot vxWorks with no startup script, load
*only* the
vxTestHarness.munch file and then execute epicsRunLibComTests — if
everything
passes you should only need to post the overall summary message
printed at
the end (at which point you'll have to Ctrl-C to get a shell back).
RTEMS is
going to be similar using rtemsTestHarness.elf, although I'm not
sure if we
build it properly for the CEXP configuration — Eric?
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- vxWorks 6.6 and EPICS R3.14.10-pre1 libCom Test Harness Ernest L. Williams Jr.
- Re: vxWorks 6.6 and EPICS R3.14.10-pre1 libCom Test Harness Andrew Johnson
<2008>
2025
2026
<2008>
2025
2026
