Dear Andrew,
>>> On Mon, 15 Sep 2008 18:07:25 JST, Andrew Johnson <[email protected]> wrote;
> Please report both bugs and successes to the tech-talk list, including the
> architecture(s) you're using and the versions of any other tools if relevent.
Thanks for your preparation, and sorry for my slow response.
I tried less popular architectures, osf-alpha, darwin, that we use,
as well as linux.
As usual, osf-alpha needs the attached patch, that is almost the
same as that against 3.14.9. I know it is dirty, but I don't know
any other solution. And the resultant build and runtest logs are
placed at
<URL:http://www-linac.kek.jp/epics/osf/>
Darwin-x86 showed error in the linkage stage of libCom shared lib,
/usr/bin/c++ -o libCom.3.14.10pre1.dylib -dynamiclib ...
Error messages are
On Tiger (8.11.1):
/usr/bin/libtool: third field (10pre1) in argument for:
-current_version 3.14.10pre1 not a proper unsigned number
On Panther (9.4.1):
ld: malformed version number: 3.14.10pre1
I know this is a minor problem. But, it seems the shared library
name on osf-alpha and linux-x86_64 are "libCom.so.3.14", that does
not lead to any error. Can we use the same naming scheme?
Regards.
Kazuro FURUKAWA <[email protected]>
Linac&KEKB, High Energy Accelerator Research Organization (KEK), Japan
Telephone: +81-29-864-5200 x4316, Facsimile: +81-29-864-0321
--- configure/os/CONFIG.Common.osf-alpha.org 2007-01-10 04:02:15.000000000 +0900
+++ configure/os/CONFIG.Common.osf-alpha 2008-09-30 20:56:39.000000000 +0900
@@ -16,7 +16,7 @@
CODE_CPPFLAGS =
POSIX_CPPFLAGS += -pthread -ieee
-POSIX_LDFLAGS += -pthread -ieee
+POSIX_LDLIBS += -pthread -ieee
OP_SYS_CPPFLAGS += -D_OSF_SOURCE
OP_SYS_LDLIBS += -lrt
--- src/ca/comBuf.h.org 2008-07-29 01:19:49.000000000 +0900
+++ src/ca/comBuf.h 2008-09-30 21:59:24.000000000 +0900
@@ -86,6 +86,9 @@
unsigned push ( comBuf & );
template < class T >
bool push ( const T & value );
+#ifdef __DECCXX /* cxx on osf-alpha, I know it is dirty but ... */
+ bool push ( const char * value );
+#endif /* __DECCXX */
unsigned push ( const T * pValue, unsigned nElem );
unsigned push ( const epicsInt8 * pValue, unsigned nElem );
@@ -197,6 +200,20 @@
return true;
+inline bool comBuf::push ( const char * value )
+ unsigned index = this->nextWriteIndex;
+ unsigned available = sizeof ( this->buf ) - index;
+ if ( sizeof ( value ) > available ) {
+ return false;
+ memcpy ( &this->buf[ index ], & value, sizeof ( value ) );
+ this->nextWriteIndex = index + sizeof ( value );
+ return true;
inline unsigned comBuf :: push ( const epicsInt8 *pValue, unsigned nElem )
return copyInBytes ( pValue, nElem );
--- /dev/null 2008-10-02 21:32:44.000000000 +0900
+++ src/libCom/osi/os/osf/osdStdio.c 2006-12-23 08:50:52.000000000 +0900
@@ -0,0 +1,54 @@
+* Copyright (c) 2002 The University of Chicago, as Operator of Argonne
+* National Laboratory.
+* Copyright (c) 2002 The Regents of the University of California, as
+* Operator of Los Alamos National Laboratory.
+* EPICS BASE Versions 3.13.7
+* and higher are distributed subject to a Software License Agreement found
+* in file LICENSE that is included with this distribution.
+#include <osiUnistd.h>
+#define epicsExportSharedSymbols
+#include <epicsStdio.h>
+#include <stdlib.h>
+epicsShareFunc int epicsShareAPI epicsSnprintf(
+ char *str, size_t size, const char *format, ...)
+ int nchars;
+ va_list pvar;
+ va_start(pvar,format);
+ nchars = epicsVsnprintf(str,size,format,pvar);
+ va_end (pvar);
+ return(nchars);
+epicsShareFunc int epicsShareAPI epicsVsnprintf(
+ char *str, size_t size, const char *format, va_list ap)
+ int nchars;
+ nchars = vsnprintf ( str, size, format, ap );
+ if (nchars == size-1) {
+ /* this means the buffer was not long enough */
+ /* we try to find a return value for epicsVsnprintf standard */
+ int i, nchars2, size2 = size * 2;
+ char *str2;
+ for (i=0; i<20; i++, size2=size2*2) {
+ str2 = malloc(size2);
+ if (str2 != NULL) {
+ nchars2 = vsnprintf ( str2, size2, format, ap );
+ if (nchars2 != size2-1) {
+ free(str2);
+ nchars = nchars2;
+ break;
+ free(str2);
+ return nchars;
- RE: EPICS Base R3.14.10-pre1 available for testing Jeff Hill
- Re: EPICS Base R3.14.10-pre1 available for testing Andrew Johnson
- EPICS Base R3.14.10-pre1 available for testing Andrew Johnson
vxWorks 6.6 and EPICS R3.14.10-pre1 libCom Test Harness Ernest L. Williams Jr.
<2008>
2025
2026
<2008>
2025
2026
