2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Base R3.14.10-pre1 available for testing
Cc: EPICS core-talk <[email protected]>
Date: Fri, 03 Oct 2008 08:21:54 +0900
Hello Andrew, hello Jeff,
Thank you for your prompt processing.  And I've just realized that
I missed your RC1 announcement.  Basically the same patch can work
for RC1 as well.
cap5 was enabled in RC1 but Tru64unix (osf-alpha) cannot co-op with
the build script.  On Tru64unix,
  perl is in /usr/bin/
  perl and xsubpp is in /usr/lib/perl-5.8.0/bin/
  (and I have perl and xsubpp in /usr/new/pkg/perl5.8/bin/)
I've tried several PATH orders, but somehow the error persists;
  /bin/sh: xsubpp: not found
or
  /bin/sh: /usr/ucb/xsubpp: not found
It seems that the typemap file location is recognized correctly.
So I don't understand the behavior yet.  I'll look it in later.
Regards.
>>> On Thu, 02 Oct 2008 11:39:46 JST,  Andrew Johnson <[email protected]> wrote;
> Hi Kazuro,
> Thanks for your report.
> On Thursday 02 October 2008 08:46:53 Kazuro FURUKAWA wrote:
> > As usual, osf-alpha needs the attached patch, that is almost the
> > same as that against 3.14.9.  I know it is dirty, but I don't know
> > any other solution.  And the resultant build and runtest logs are
> > placed at
> >   <URL:http://www-linac.kek.jp/epics/osf/>
> Jeff Hill has already commented on your modifications to comBuf.h and I have
> just committed the change to CONFIG.Common.osf-alpha.  As to your
> implementation of epicsVsnprintf() we do not think this is necessary, since
> osf-alpha is not the only target architecture that suffers from this
> particular problem and .  I have modified the text in the Application
> Developers Guide that describes these two functions to make it clear that the
> return value is not guaranteed.  I may take out the return value tests from
> the libCom/test/epicsStdioTest.c program too.
> > Darwin-x86 showed error in the linkage stage of libCom shared lib,
> >   /usr/bin/c++ -o libCom.3.14.10pre1.dylib -dynamiclib ...
> We already fixed the problem with the version number that affected both darwin
> and WIN32, which was caused by my putting the "-pre1" part in the wrong
> variable in CONFIG_BASE_VERSION.  We have taken steps to ensure that this
> shouldn't happen in the future, and it shouldn't have been an issue in
> the -RC1 release.
> - Andrew
> Talk is cheap. Show me the code. -- Linus Torvalds
Kazuro FURUKAWA <[email protected]>
 Linac&KEKB,  High Energy Accelerator Research Organization (KEK), Japan
Re: EPICS Base R3.14.10-pre1 available for testing Andrew Johnson
Prev: Re: EPICS Base R3.14.10-pre1 available for testing Andrew Johnson
Next: libCom tests for EPICS BASE R3.14.10-RC1 :epicsMessageQueueTest Ernest L. Williams Jr.
Index: 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS Base R3.14.10-pre1 available for testing Andrew Johnson
