Hi Kazuro,
On Thursday 02 October 2008 18:21:54 Kazuro FURUKAWA wrote:
> cap5 was enabled in RC1 but Tru64unix (osf-alpha) cannot co-op with
> the build script. On Tru64unix,
> perl is in /usr/bin/
> perl and xsubpp is in /usr/lib/perl-5.8.0/bin/
> (and I have perl and xsubpp in /usr/new/pkg/perl5.8/bin/)
> I've tried several PATH orders, but somehow the error persists;
> /bin/sh: xsubpp: not found
> or
> /bin/sh: /usr/ucb/xsubpp: not found
> It seems that the typemap file location is recognized correctly.
> So I don't understand the behavior yet. I'll look it in later.
There is a problem with the installation of the xsubpp program from Perl
versions before about 5.8.4: if you look at the first line it
says "#!./miniperl" — the miniperl interpreter is part of the Perl build
system which is not installed, but xsubpp can also be run by the regular Perl
interpreter. Newer Perl versions insert the following 3-line prologue (or
its equivalent) at the top of the file when they install xsubpp:
#!/usr/bin/perl
eval 'exec /usr/bin/perl -S $0 ${1+"$@"}'
if $running_under_some_shell;
I suspect if you add the above to your xsubpp, the build will complete
properly.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
- Re: EPICS Base R3.14.10-pre1 available for testing Andrew Johnson
- Re: EPICS Base R3.14.10-pre1 available for testing Kazuro FURUKAWA
vxWorks 6.6 on MVME3100 target: libCom test harness for EPICS R3.14.10-RC1 Ernest L. Williams Jr.
<2008>
2025
2026
<2008>
2025
2026
