Hi Ernest,
On Friday 03 October 2008 00:38:15 Ernest L. Williams Jr. wrote:
> The libCom test did not pass for RHEL WS 5.2 (64-bit Linux)
> epicsMessageQueueTest......FAILED test 58
> Failed 1/58 tests, 98.28% okay
> Failed Test Stat Wstat Total Fail Failed List of Failed
>---- epicsMessageQueueTest.t 58 1 1.72% 58
That particular test has failed for me sometimes through the test harness, but
if you run src/libCom/test/O.linux-x86_64/epicsMessageQueueTest manually it
usually passes. Ooh no it didn't, the last test didn't report at all...
Looking at the code I can see why; the issue is in the test program, not what
it's actually testing. I've modified the program so it will now shut down
properly and actually report the results of the last test.
Thanks for the report,
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
- Re: libCom tests for EPICS BASE R3.14.10-RC1 :epicsMessageQueueTest Ernest L. Williams Jr.
- libCom tests for EPICS BASE R3.14.10-RC1 :epicsMessageQueueTest Ernest L. Williams Jr.
Re: EPICS Base R3.14.10-pre1 available for testing Andrew Johnson
Re: EPICS Base R3.14.10-pre1 available for testing Kazuro FURUKAWA
<2008>
2025
2026
<2008>
2025
2026
