2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: libCom tests for EPICS BASE R3.14.10-RC1 :epicsMessageQueueTest
Cc: [email protected]
Date: Mon, 06 Oct 2008 14:27:32 -0700
Andrew Johnson wrote:
Hi Ernest,
On Friday 03 October 2008 00:38:15 Ernest L. Williams Jr. wrote:
The libCom test did not pass for  RHEL WS 5.2 (64-bit Linux)
epicsMessageQueueTest......FAILED test 58
        Failed 1/58 tests, 98.28% okay
Failed Test             Stat Wstat Total Fail  Failed  List of Failed
---- epicsMessageQueueTest.t               58    1   1.72%  58
That particular test has failed for me sometimes through the test harness, but if you run src/libCom/test/O.linux-x86_64/epicsMessageQueueTest manually it usually passes. Ooh no it didn't, the last test didn't report at all... Looking at the code I can see why; the issue is in the test program, not what it's actually testing. I've modified the program so it will now shut down properly and actually report the results of the last test.
Thanks for the report,
No problem,
All tests pass successfully now:
Red Hat Enterprise Linux Client release 5.2 (Tikanga)
Linux jaguar 2.6.18-92.1.13.el5 #1 SMP Thu Sep 4 03:51:21 EDT 2008 x86_64 x86_64 x86_64 GNU/Linux
gcc version 4.1.2 20071124 (Red Hat 4.1.2-42)
make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. T_A=linux-x86_64 runtests
All tests successful.
Files=21, Tests=1589, 392 wallclock secs ( 0.22 cusr + 3.97 csys = 4.19 CPU)
Ernest
- Andrew
libCom tests for EPICS BASE R3.14.10-RC1 :epicsMessageQueueTest Ernest L. Williams Jr.
Re: libCom tests for EPICS BASE R3.14.10-RC1 :epicsMessageQueueTest Andrew Johnson
Prev: Re: EPICS Base R3.14.10-pre1 available for testing Kazuro FURUKAWA
Next: R3.14.10-RC2 out on Thursday Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: libCom tests for EPICS BASE R3.14.10-RC1 :epicsMessageQueueTest Andrew Johnson
Next: vxWorks 6.6 on MVME3100 target: libCom test harness for EPICS R3.14.10-RC1 Ernest L. Williams Jr.
