Hi Lewis,
On Saturday 01 November 2008 15:56:52 J. Lewis Muir wrote:
> I'm having a problem with errlogVprintf. When I use it, messages are
> not written to the console; they only get written into the errlog
> facility. I would expect the messages to be written to the console like
> they are for errlogPrintf.
Ooh, code archaeological research <grin>...
There is a note in the latest AppDevGuide in section 10.2.1 that says
> If epicsThreadIsOkToBlock is true, which is true during iocInit,
> errlogVprintf does NOT send output to the errlog task.
That matches the behavior you're seeing. Also, section 10.5 says:
> The errlog system can also display messages on the ioc console. It calls
> epicsThreadIsOkToBlock to decide when to display the message. If it is OK
> to block, the message is displayed by the same thread that calls one of the
> errlog print routines. If it is not OK to block, errlogThread displays the
> messages.
The last sentence is obviously not true, and was added for the R3.14.7
AppDevGuide whereas the contradiction in 10.2.1 was added later for the
R3.14.8 version.
The middle sentence "by the same thread" is important in understanding why the
existing code is like it is. Developers don't particularly like it if their
errlogPrintf() output doesn't come out immediately; they expect the sequence
of calls
printf("A\n");
errlogPrintf("B\n");
printf("C\n");
to generate "A" "B" and "C" in order, which is why the "by the same thread"
part was added. Now if epicsThreadIsOkToBlock() returns false we must avoid
blocking the thread (any kind of printf() to a file descriptor is potentially
blocking) so we have no choice but to punt the printf() to the errlogThread,
but where blocking isn't a problem it's nicer to do the printf() directly in
the calling thread.
One other piece of evidence is relevent at this point: The macro va_copy() was
only standardized in C99, and is not yet available on all of the platforms we
have to support. Unfortunately without va_copy() it's not possible for
errlogVprintf() to call vfprintf(stderr, pFormat, pvar) followed by
tvsnPrint(pbuffer, ..., pvar) because we have no way to reset pvar back to
point to the first item in the va_list.
So why doesn't it just convert the text into the buffer and then fprintf()
that? I think that is probably because we have a strict length limit on the
output message (normally 256 bytes, but can be made longer at init time).
The current implementation of errlogPrintf() ensures that the whole message
will always get printed to the console, although the logged version will get
truncated.
Looking through CVS, back in R3.14.7 the 'direct output to console'
functionality was implemented in errlogVprintf(), but it didn't work on all
platforms because it passed pvar first to vfprintf() and then to tvsnPrint()
without resetting it in between (that works on some architectures, but not on
PowerPC or x86_64 CPUs). In R3.14.8.2 it was moved to errlogPrintf() and the
note about errlogVprintf() added to the AppDevGuide.
I hope that explains how we got to where we are, the question is now what to
do about it? I agree that there should be no difference in the visible
behavior between the two errlog(P|Vp)rintf routines, so what we have now
needs at least some reworking.
The question I have for any core-talk readers still paying attention is:
How important is it that errlogPrintf() and friends directly call
fprintf(stderr) when called in a thread that is allowed to block?
My inclination would be to do what Lewis proposes and do all the
console output from the errlogThread, but that would often cause
the example above to output "A", "C" and then later "B".
Comments please, if you care...
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
- Re: errlogVprintf does not print messages to console Eric Norum
Re: EPICS R3.14.10 version number Andrew Johnson
<2008>
2025
2026
<2008>
2025
2026
