2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: errlogVprintf does not print messages to console
Cc: Core-Talk <[email protected]>, Mark Rivers <[email protected]>
Date: Mon, 3 Nov 2008 15:25:45 -0600
On Nov 3, 2008, at 2:40 PM, Andrew Johnson wrote:
The middle sentence "by the same thread" is important in understanding why the existing code is like it is. Developers don't particularly like it if their errlogPrintf() output doesn't come out immediately; they expect the sequence
of calls
	printf("A\n");
	errlogPrintf("B\n");
	printf("C\n");
to generate "A" "B" and "C" in order, which is why the "by the same thread" part was added. Now if epicsThreadIsOkToBlock() returns false we must avoid blocking the thread (any kind of printf() to a file descriptor is potentially blocking) so we have no choice but to punt the printf() to the errlogThread, but where blocking isn't a problem it's nicer to do the printf() directly in
the calling thread.
The question I have for any core-talk readers still paying attention is:
   How important is it that errlogPrintf() and friends directly call
   fprintf(stderr) when called in a thread that is allowed to block?
   My inclination would be to do what Lewis proposes and do all the
   console output from the errlogThread, but that would often cause
   the example above to output "A", "C" and then later "B".
The decision comes down to how heavily you weight the expectations that you mention in the first paragraph above. As you pointed out, the developer's guide does state (or at least imply pretty strongly) that
 	printf("A\n");
	printf("C\n");
will generate "A" "B" and "C" in order. Now this promise is to be rescinded. About par for the course at this time of year in this country, I suppose.........
I think that it is fairly easy to argue that there should not be any expectation that errlogPrintf output appear in any fixed relation to printf/fprintf output.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Re: errlogVprintf does not print messages to console Andrew Johnson
Prev: Re: errlogVprintf does not print messages to console Andrew Johnson
Next: Re: errlogVprintf does not print messages to console Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
