2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: errlogVprintf does not print messages to console
To: Eric Norum <[email protected]>
Cc: Core-Talk <[email protected]>, Mark Rivers <[email protected]>
Date: Mon, 3 Nov 2008 16:03:00 -0600
On Monday 03 November 2008 15:25:45 Eric Norum wrote:
> On Nov 3, 2008, at 2:40 PM, Andrew Johnson wrote:
> >    How important is it that errlogPrintf() and friends directly call
> >    fprintf(stderr) when called in a thread that is allowed to block?
> >    My inclination would be to do what Lewis proposes and do all the
> >    console output from the errlogThread, but that would often cause
> >    the example above to output "A", "C" and then later "B".
> The decision comes down to how heavily you weight the expectations
> that you mention in the first paragraph above.  As you pointed out,
> the developer's guide does state (or at least imply pretty strongly)
> that
>   	printf("A\n");
> 	errlogPrintf("B\n");
> 	printf("C\n");
> will generate "A" "B" and "C" in order.  Now this promise is to be
> rescinded.
It doesn't have to be; it wouldn't be hard to keep the existing fprintf() code
in errlogPrintf(), removing its call to errlogVprintf(), and arrange for
errlogVprintf() to pass its converted buffer to fprintf() if blocking is
allowed.  That would be better than we have now and the only strange behavior
would be that the 256 byte length limitation doesn't apply to the console
output from errlogPrintf().
> I think that it is fairly easy to argue that there should not be any
> expectation that errlogPrintf output appear in any fixed relation to
> printf/fprintf output.
Doing so would certainly simplify the code in errlog.c, making it easier to
maintain.  However I'm still willing to listen to objections.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
Re: errlogVprintf does not print messages to console Andrew Johnson
Re: errlogVprintf does not print messages to console Eric Norum
Prev: Re: errlogVprintf does not print messages to console Eric Norum
Next: Re: seq! Liu, Gongfa
Index: 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
