But since the POSIX timer API is out there in the real world, and
manufacturers are now writing their device libraries using it, do we
have any choice but to be compatible with it?
-----Original Message-----
Sent: Friday, January 30, 2009 12:45 PM
To: Mark Rivers
Cc: Andrew Johnson; Core-Talk
Subject: Re: EPICS and interruptable system calls
All 'slow' system calls are at risk. This includes all socket I/O and
serial port I/O. The ones I worry about the most are writes to
sockets or tty ports. I have a feeling that this is going to be a
rather dusty corner case and that some systems are not going to be
doing the right thing. I wouldn't be surprised, for example, if the
write returned -1 with errno set to EINTR -- then how would you know
where to restart the operation? Sure, the right thing for the system
to do would be to return the actual number of bytes sent before the
signal occurred, but I suspect that not all kernel developers are as
smart as us ;-)
My next concern is about I/O from things like the RPC library. Are
all these libraries capable of correctly dealing with EINTR?
On Jan 30, 2009, at 12:30 PM, Mark Rivers wrote:
> Eric and Andrew,
> According to this message from Prosilica they are simply using the
> the new POSIX Timer API provided in librt.so. I've looked at the
> documentation for this, and indeed the default for the timers is to
> use SIGALRM, and indeed if one uses this library then all system
> calls need to be restarted if they terminate with EINTR.
> I realize this is a big job, but it seems to me that allowing the
> use of the POSIX Timer API within EPICS applications is actually a
> very good idea. I have made the minor change to epicsThreadSleep in
> libCom/osi/os/posix/osdThread.c, and it now works fine when the
> Prosilica driver is initialized and thus SIGALRM signals are
> happening frequently. I am not sure how many other system calls in
> EPICS base would need to be changed. I found, for example, that
> disk I/O I am doing in the areaDetector application, using the
> netCDF library, seems to work fine. They do not appear to be
> retrying if write() fails. The documentation in the link below says
> that record-oriented I/O will never return partial data and hence
> not need to be retried.
> If the epicsTimer were changed to use that API would it be possible
> to get timer resolution better than, for example, the 0.01 second
> that Linux now provides?
> Mark
> From: Arlin Kalenchuk [mailto:[email protected]]
> Sent: Thursday, January 29, 2009 3:06 PM
> To: Mark Rivers
> Cc: Eric Norum; Andrew Johnson; John M. Skinner
> Subject: RE: More information
> Hello Mark,
> The last version we sent you should be able to find the camera ...
> It is the version you should be using to avoid the seg-fault issues
> you have encountered.
> We do not use any signal in the driver, aside from SIGALRM which is
> use by the POSIX Timer API (librt.so). As a result of this, you
> really should be protecting EVERY system call that can be
> interrupted by a signal (usually stated in the call's
> documentation). This can be done as shown in the version of
> epicsThreadSleep() we sent earlier, or by using the macro
> TEMP_FAILURE_RETRY:
http://www.gnu.org/software/libtool/manual/libc/Interrupted-Primitives.h
tml
> The flag SA_RESTART is unfortunately not respected by all system
> calls, if at all on Linux.
> I understand that rewriting your code isn't an attractive option.
> We'd be more than happy to get rid of the POSIX Timer API we are
> using, however we aren't aware of any suitable substitute. If you
> know of something, we'd love to hear about it.
> Arlin Kalenchuk
> Prosilica Inc.
> 101 - 3750 North Fraser Way
> Burnaby, BC, Canada, V5J 5E9
> Tel: 604-875-8855 ext 124
> Fax: 604-875-8856
> www.prosilica.com
> From: Mark Rivers [mailto:[email protected]]
> Sent: Thursday, January 29, 2009 11:57 AM
> To: Arlin Kalenchuk
> Subject: More information
> Dear Arlin,
> I have now done some more tests. I modified epicsThreadSleep() as
> you suggested, so that it retries if it failed.
> My driver and other parts of EPICS are the same as for the previous
> results I sent, i.e. I am waiting 5 seconds 3 times in my driver,
> and I am not installing any signal handler for SIGALRM in EPICS
> channel access in base.
> Here is the result with your new version of libPvAPI.a
> prosilicaConfig("PS1", 101271, 50, 200000000)
> 2009/01/29 13:37:18.846 Calling epicsThreadSleep for 5 seconds
> before calling PvInitialize()
> 2009/01/29 13:37:23.846 Return from epicsThreadSleep for 5 seconds
> 2009/01/29 13:37:23.848 Calling epicsThreadSleep for 5 seconds after
> 2009/01/29 13:37:30.835 Return from epicsThreadSleep for 5 seconds
> after calling PvInitialize()
> Called siginterrupt, status=0
> 2009/01/29 13:37:30.835 Calling epicsThreadSleep for 5 seconds after
> calling PvInitialize() and siginterrupt()
> 2009/01/29 13:37:35.835 Return from epicsThreadSleep for 5 seconds
> after calling PvInitialize() and siginterrupt()
> 2009/01/29 13:37:35.843 prosilica:connectCamera: Cannot find camera
> 101271
> prosilica:prosilica: cannot connect to camera 101271, manually
> connect when available.
> Note that the call to epicsThreadSleep now takes 5.0, 7.0 and 5.0
> seconds the 3 times I call it. Before modifying epicsThreadSleep it
> was only 1ms on the last 2 calls.
> However, this does not fix the problem of not finding the camera.
> It is not finding the camera, which is available.
> I then simply relinked my application with the Oct. 3. version of
> libPvAPI.a. It produces the following output:
> 2009/01/29 13:45:02.143 Calling epicsThreadSleep for 5 seconds
> 2009/01/29 13:45:07.143 Return from epicsThreadSleep for 5 seconds
> 2009/01/29 13:45:07.145 Calling epicsThreadSleep for 5 seconds after
> 2009/01/29 13:45:12.145 Return from epicsThreadSleep for 5 seconds
> 2009/01/29 13:45:12.145 Calling epicsThreadSleep for 5 seconds after
> 2009/01/29 13:45:17.145 Return from epicsThreadSleep for 5 seconds
> asynSetTraceIOMask("PS1",0,2)
> The old version of the driver works fine. Each call to
> epicsThreadSleep waits for 5.0 seconds as it should. It finds the
> camera, and I can control the camera fine.
> With this version of the driver I also ran my file saving plugin. I
> was able to stream 1000 frames to disk at 50 frames/second, for a
> total of 348MB. So perhaps my worries about read() and write()
> function calls being interrupted and not completing correctly are
> unfounded? Can you tell me if this is true, do I need to worry
> about those calls failing because of your drivers use of signals?
> Exactly what Linux system calls do I need to retry if I use your
> driver in my application?
> The readline library still does not work correctly. It does not
> output a newline between commands and command line recall does not
> work.
> Bottom line: I can make the old version of the library work (with
> significant issues), but the new version of the library will not
> find the camera.
> Thanks,
> Mark
> From: Mark Rivers
> Sent: Thursday, January 29, 2009 1:33 PM
> To: 'Arlin Kalenchuk'
> Cc: 'Eric Norum'; 'Andrew Johnson'; 'John M. Skinner'
> Subject: RE: EPICS
> I just did a Google search on readline and SIGALRM. Readline does
> by default install a signal handler for SIGALRM:
> http://www.delorie.com/gnu/docs/readline/rlman_43.html
> 2.5 Readline Signal Handling
> Signals are asynchronous events sent to a process by the Unix
> kernel, sometimes on behalf of another process. They are intended to
> indicate exceptional events, like a user pressing the interrupt key
> on his terminal, or a network connection being broken. There is a
> class of signals that can be sent to the process currently reading
> input from the keyboard. Since Readline changes the terminal
> attributes when it is called, it needs to perform special processing
> when such a signal is received in order to restore the terminal to a
> sane state, or provide application writers with functions to do so
> manually.
> Readline contains an internal signal handler that is installed for a
> number of signals (SIGINT, SIGQUIT, SIGTERM, SIGALRM, SIGTSTP,
> SIGTTIN, and SIGTTOU). When one of these signals is received, the
> signal handler will reset the terminal attributes to those that were
> in effect before readline() was called, reset the signal handling to
> what it was before readline() was called, and resend the signal to
> the calling application. If and when the calling application's
> signal handler returns, Readline will reinitialize the terminal and
> continue to accept input. When a SIGINT is received, the Readline
> signal handler performs some additional work, which will cause any
> partially-entered line to be aborted (see the description of
> rl_free_line_state() below).
> There is an additional Readline signal handler, for SIGWINCH, which
> the kernel sends to a process whenever the terminal's size changes
> (for example, if a user resizes an xterm). The Readline SIGWINCH
> handler updates Readline's internal screen size information, and
> then calls any SIGWINCH signal handler the calling application has
> installed. Readline calls the application's SIGWINCH signal handler
> without resetting the terminal to its original state. If the
> application's signal handler does more than update its idea of the
> terminal size and return (for example, a longjmp back to a main
> processing loop), it must call rl_cleanup_after_signal() (described
> below), to restore the terminal state.
> Readline provides two variables that allow application writers to
> control whether or not it will catch certain signals and act on them
> when they are received. It is important that applications change the
> values of these variables only when calling readline(), not in a
> signal handler, so Readline's internal signal state is not corrupted.
> Variable: int rl_catch_signals
> If this variable is non-zero, Readline will install signal handlers
> for SIGINT, SIGQUIT, SIGTERM, SIGALRM, SIGTSTP, SIGTTIN, and SIGTTOU.
> The default value of rl_catch_signals is 1.
> Mark
> From: Mark Rivers
> Sent: Thursday, January 29, 2009 1:06 PM
> Subject: RE: EPICS
> Dear Arlin,
> I am making some real progress in getting the Prosilica cameras
> running under Linux. I now have a configuration which allows me to
> reliably start my application, connnect to the camera and read
> frames. However, there are some side-effects that we really need to
> work out.
> The first problem is the one I mentioned in my previous message: a
> call to PvInitialize appears to result in a call to
> siginterrupt(SIGALRM, 1) or the equivalent. This means that all
> "slow" system calls such as nanosleep(), read(), write(), etc. can
> return prematurely and need to be retried. I really don't think it
> is an option to rewrite all of EPICS to look for all system calls
> that could be interrupted and retry them.
> My first set of tests is with the old (Oct.3 2008) version of the
> driver.
> I modified my driver temporarily to the following to do 3 things:
> 1) Do an epicsThreadSleep(5) before I call PvInitialize(). It
> works as expected.
> 2) Do an epicsThreadSleep(5) after calling PvInitialize(). It
> returns in 1.0 second, not 5.0.
> 3) Call siginterrupt(SIGALRM, 0) to turn off interruptable
> system calls, and then call epicsThreadSleep(5) again. To my
> surprise it still returns in 1.0 or 2.0 seconds, not 5.0 seconds. I
> don't understand this.
> asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR, "Calling
> epicsThreadSleep for 5 seconds before calling PvInitialize()\n");
> epicsThreadSleep(5.);
> asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR, "Return from
> if (!PvApiInitialized) {
> status = PvInitialize();
> if (status) {
> printf("%s:%s: ERROR: PvInitialize failed for camera %d,
> status=%d\n",
> driverName, functionName, uniqueId, status);
> return;
> PvApiInitialized = 1;
> epicsThreadSleep for 5 seconds after calling PvInitialize()\n");
> #ifdef linux
> /* Try changing the siginterrupt to not interrupt system calls */
> status = siginterrupt(SIGALRM, 0);
> printf("Called siginterrupt, status=%d\n", status);
> #endif
> /* It appears to be necessary to wait a little for the PvAPI
> library to find the cameras */
> epicsThreadSleep for 5 seconds after calling PvInitialize() and
> siginterrupt()\n");
> siginterrupt()\n");
> /* Try to connect to the camera.
> * It is not a fatal error if we cannot now, the camera may be
> off or owned by
> * someone else. It may connect later. */
> status = connectCamera();
> Here is the output when I start my application:
> 2009/01/29 12:27:22.357 Calling epicsThreadSleep for 5 seconds
> 2009/01/29 12:27:27.357 Return from epicsThreadSleep for 5 seconds
> 2009/01/29 12:27:27.359 Calling epicsThreadSleep for 5 seconds after
> 2009/01/29 12:27:28.359 Return from epicsThreadSleep for 5 seconds
> 2009/01/29 12:27:28.359 Calling epicsThreadSleep for 5 seconds after
> 2009/01/29 12:27:30.359 Return from epicsThreadSleep for 5 seconds
> Note that the second 2 calls to epicsThreadSleep returned in 1.0 and
> 2.0 seconds respectively, not 5.0 seconds.
> The application connected to the camera and exchanged some
> information, but still crashed with a segfault.
> The traceback showed that a signal handler in EPICS base was being
> called, and then calling your driver function.
> I then modified EPICS base to remove the calls to install our
> handler for SIGALRM (which simply calls any preexisting handler). I
> was told that on Linux EPICS does not actually generate any SIGALRM
> signals. I removed 2 calls to epicsSignalInstallSigAlarmIgnore() in
> the EPICS channel access code. Once I did that my application runs
> OK, and can control the camera, read frames, etc.
> I believe I may understand that problem. Once I removed the calls
> to epicsSignalInstallSigAlarmIgnore() it appears that the readline
> library is no longer working: it does not insert newlines when I
> type Enter, and command line recall no longer works. I strongly
> suspect that the Linux readline library is using SIGALRM, and
> somehow that was interacting badly with your driver when had
> installed our own signal handler for SIGALRM. Perhaps readline was
> generating a SIGALRM signal and then we were calling your driver
> when you did not expect it?
> I then did the identical test but with my application linked with
> the new version of libPvAPI.a that you sent yesterday.
> That version behaves very differently, as seen in this output:
> 2009/01/29 12:59:08.761 Calling epicsThreadSleep for 5 seconds
> 2009/01/29 12:59:13.761 Return from epicsThreadSleep for 5 seconds
> 2009/01/29 12:59:13.762 Calling epicsThreadSleep for 5 seconds after
> 2009/01/29 12:59:13.763 Return from epicsThreadSleep for 5 seconds
> 2009/01/29 12:59:13.763 Calling epicsThreadSleep for 5 seconds after
> 2009/01/29 12:59:13.763 prosilica:connectCamera: Cannot find camera
> 101271
> The first call to epicsThreadSleep(5) waits 5 seconds as expected.
> But the next 2 calls to epicsThreadSleep(5) return in 1 msec or
> less. This is not enough time for your library to find all the
> cameras, so it fails to find the camera. It appears that the new
> version of your library is generating SIGALRM signals over 1000
> times per second because the nanosleep() is always returning in
> 1msec or less. Is this true?
> So the bottom line is that I can make my application "work" with the
> old version of the library. But it still has serious problems
> because EPICS is not going to function well if system calls like
> nanosleep(), read() and write() can be interrupted.
> Is it possible to re-write your driver so that it does not call
> siginterrupt(SIGALRM, 1)? We can help provide code for timers or
> other functions if that is what is needed.
> Thanks,
> Mark
> From: Mark Rivers
> Sent: Thursday, January 29, 2009 12:07 PM
> Subject: RE: EPICS
> Hi Arlin,
> The problem is that EPICS has hundreds of calls to system functions
> that can be interrupted by signals such as SIGALRM, including
> read(), write(), etc. It is simply not possible to change EPICS to
> be compatible with a call to:
> siginterrupt(SIGARLM, 1);
> That would require way too much modification to the tens of
> thousands of lines of code in EPICS.
> Does your driver use a call to siginterrupt such as that above?
> I have done some experimenting with adding a call to
> siginterrupt(SIGALRM, 0) after the call to PvInitialize(). However,
> this does not seem to fix the problem, it still seems to interrupt
> calls to nanosleep(). Do you repeatedly call siginterrupt()?
> I have actually made a change to EPICS to remove our calls to catch
> SIGALRM signals. That actually fixes the seg faults we were getting
> with the old version of the driver, and I can actually reliably
> collect images. However, we don't have an acceptable solution until
> we resolve the problem with interruptable system calls since calls
> to nanosleep will return too soon, calls to write() or read() may
> return without completing properly, etc.
> I will send a more detailed message in a few minutes that explains
> what I have done and how it works better now. I will also make
> tests with both your old library and the new version you sent
> yesterday.
> Thanks,
> Mark
> Sent: Thursday, January 29, 2009 11:26 AM
> To: Mark Rivers
> Subject: RE: EPICS
> The POSIX function nanosleep() can be interrupted by a signal (such
> as SIGALRM which is used by the Linux timer API). When this occurs,
> the function will return -1 and errno will be set to EINTR. The
> epicsThreadSleep() function could be modified as follow:
> epicsShareFunc void epicsShareAPI epicsThreadSleep(double seconds)
> struct timespec delayTime;
> struct timespec remainingTime;
> double nanoseconds;
> delayTime.tv_sec = (time_t)seconds;
> nanoseconds = (seconds - (double)delayTime.tv_sec) *1e9;
> delayTime.tv_nsec = (long)nanoseconds;
> while(nanosleep(&delayTime,&remainingTime) == -1)
> delayTime = remainingTime;
> Arlin Kalenchuk
> Prosilica Inc.
> Fax: 604-875-8856
> www.prosilica.com
> Sent: Wednesday, January 28, 2009 4:41 PM
> To: Arlin Kalenchuk
> Subject: RE: EPICS
> Hi Arlin,
> Thanks for the quick response.
> I untarred that file and linked my application with the following
> library from it.
> -rw-r--r-- 1 epics epics 2300264 Jan 28 16:14 PvAPI1.19.3/lib-pc/
> x86/4.2/libPvAPI.a
> The behavior is different, it does not consistently crash. But it
> still does not work correctly. It is not finding the camera,
> because the epicsThreadSleep function we are using is not working
> correctly when linked with your library.
> My code does the following.
> /* Initialize the Prosilica PvAPI library
> * We get an error if we call this twice, so we need a global
> flag to see if
> * it's already been done.*/
> if (status) {
> status=%d\n",
> return;
> asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR, "Sleeping for 20
> seconds\n");
> epicsThreadSleep(20.0);
> asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR, "Done sleeping for
> 20 seconds\n");
> off or owned by
> In the normal version of this code the call to epicsThreadSleep() is
> for 0.2 seconds (not 20 seconds), and it does not print the
> messages. That 0.2 second delay is always sufficient (on Windows)
> to allow your code to have found the cameras.
> I changed it to 20 seconds just to prove that it is not sleeping at
> all! My code now prints out the message "Sleeping for 20 seconds",
> but in fact it does not sleep it all, it immediately goes to the
> next statement and calls connectCamera(), which fails.
> There must be something that your library is doing which causes the
> epicsThreadSleep() function to return prematurely under Linux.
> Here is the output when I run my program. As shown by the
> timestamps on these messages, there is only 6 milliseconds between
> the message "Sleeping for 20 seconds" and the "Done sleeping for 20
> second seconds" message, so the epicsThreadSleep command is
> returning immediately and connectCamera() is failing.
> 2009/01/28 18:00:07.462 Sleeping for 20 seconds
> 2009/01/28 18:00:07.468 Done sleeping for 20 seconds
> 2009/01/28 18:00:09.463 prosilica:connectCamera: Cannot find camera
> 101271
> When I execute this modified version of my driver on Windows it
> works fine, and I get the following. It sleeps for 20 seconds, and
> does not get an error trying to connect to the camera.
> 2009/01/28 18:04:45.640 Sleeping for 20 seconds
> 2009/01/28 18:05:05.641 Done sleeping for 20 seconds
> On Posix platforms (e.g. Linux) EPICS uses the following code to
> implement epicsThreadSleep()
> double nanoseconds;
> nanosleep(&delayTime,&remainingTime);
> So it looks like nanosleep is returning before the time has elapsed.
> I then reverted back to the previous version of your library. When
> I run that I get the following:
> 2009/01/28 17:55:30.547 Sleeping for 20 seconds
> 2009/01/28 17:55:31.547 Done sleeping for 20 seconds
> So it does not wait for 20 seconds, but it does wait for 1.0 seconds
> and it does find the camera. The fact that it only sleeps for 1
> second instead of 20 is obviously a problem, but at least it sleeps
> long enough to allow your code time to find the cameras. But then
> it crashes later, after some communication with the camera, with the
> seg fault like I sent you previously. Here is the backtrace from gdb:
> (gdb) bt
> #0 0x080f6753 in SIGAction ()
> #1 0x0823d61d in ignoreSigAlarm (signal=14) at ../../../src/libCom/
> osi/os/posix/osdSignal.cpp:109
> #2 <signal handler called>
> #3 0x00110416 in __kernel_vsyscall ()
> #4 0x002228ff in sigprocmask () from /lib/libc.so.6
> #5 0x05ae08f7 in ?? () from /lib/libreadline.so.5
> #6 <signal handler called>
> #7 0x00110416 in __kernel_vsyscall ()
> #8 0x002ce671 in select () from /lib/libc.so.6
> #9 0x080f6b3e in pPvMultiplexer::Body ()
> #10 0x080fa720 in _ThreadFunction ()
> #11 0x003b932f in start_thread () from /lib/libpthread.so.0
> #12 0x002d620e in clone () from /lib/libc.so.6
> Mark
> Sent: Wednesday, January 28, 2009 4:40 PM
> To: Mark Rivers
> Subject: EPICS
> Hello Mark,
> Can you try running the attached engineering version of our latest
> driver? It should fix the issue you're having. Let us know the
> results.
> Thanks.
> Arlin Kalenchuk
> Prosilica Inc.
> Fax: 604-875-8856
> www.prosilica.com
> Sent: Tuesday, January 27, 2009 1:23 PM
> To: Arlin Kalenchuk
> Subject: RE: EPICS
> Dear Arlin,
> I have not resolved the issue, it is still outstanding.
> The customer you mention may be John Skinner from Brookhaven
> National Laboratory? He got a Prosilica camera on trial, and hoped
> to use it with my EPICS software. Unfortunately he had the same
> trouble I did, it would crash the program after initial successful
> communication with the camera. This really looks like a problem
> with Linux signals being used both by EPICS and by your driver.
> There are a lot of potential Prosilica users who want to run my
> EPICS software under Linux. My software works fine on Windows, but
> crashes on Linux. My code is identical in terms of how it
> communicates with your driver in both cases.
> Thanks,
> Mark
> Sent: Tuesday, January 27, 2009 2:51 PM
> To: Mark Rivers
> Subject: EPICS
> Hello Mark,
> A customer recently contacted us, who apparently is running into the
> same problems you had running our GigE series cameras with EPICS.
> Paul Kozik forwarded me your email correspondence, but it seems to
> me nobody got back to you after a Dec 18th email:
> "Paul,
> While most of the time the backtrace is the one I sent previously,
> ocassionally it is as follows:
> (gdb) bt
> #0 0x0808ce33 in SIGAction ()
> #1 0x0821bf4d in ignoreSigAlarm (signal=14) at
> ../../../src/libCom/osi/os/posix/osdSignal.cpp:109
> Have you managed to resolve this issue, or is it still outstanding?
> Thanks,
> Arlin Kalenchuk
> Prosilica Inc.
> Fax: 604-875-8856
> www.prosilica.com
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- Re: EPICS and interruptable system calls Andrew Johnson
- EPICS and interruptable system calls Mark Rivers
- Re: EPICS and interruptable system calls Eric Norum
<2009>
2025
2026
<2009>
2025
2026
