Subject: |
Re: Local CA out links broken during PINI |
"Schoeneburg, Bernd" <[email protected]> |
To: |
EPICS Core Talk <[email protected]> |
Date: |
Fri, 20 Feb 2009 17:06:35 +0100 |
Ralph Lange schrieb:
For the Redundant IOC , it has the interesting side effect that you
can select if the record should be processed at boot time, or after
the IOC has become active.
(If the IOC switches back and forth between active and inactive, would
UP records be processed whenever it gets active? Do we need to
distinguish between "Once UP" and "Whenever UP"?)
This is really a good idea.
We have an additional requirement: The record code of some records need
to know if it is processed normally, the first time at all or the first
time after the ioc became active. Up to now we solved this problem by
introducing a new field in those records and a function, which sets
these fields, is registered to the redundancy task (RMT). These records
are in a linked list. When the ioc becomes active the RMT sets the
fields to a value, so that the record code can see that the record is
processed first after becoming active.
A more general solution for this problem would be welcome.
- Bernd
- Re: Local CA out links broken during PINI Ralph Lange
- Re: Local CA out links broken during PINI Andrew Johnson
<2009>
2025
2026
<2009>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
