2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Local CA out links broken during PINI
To: Ralph Lange <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Fri, 20 Feb 2009 11:40:23 -0600
Hi Ralph,
On Friday 20 February 2009 03:51:43 Ralph Lange wrote:
> Idea: Why not introduce an additional PINI sweep, and change the PINI
> field to be a three-option choice?
> "NO", "YES", "UP": NO and YES yield the classical behaviour, while "UP"
> puts the record into the second PINI phase, that runs *after* the CA
> client and server are started (I.e., when the IOC is UP).
> Should be compatible, shouldn't break existing stuff, allows CA/CP in
> PINI processing.
> For the Redundant IOC it has the interesting side effect that you can
> select if the record should be processed at boot time, or after the IOC
> has become active.
I like it!
> (If the IOC switches back and forth between active and inactive, would
> UP records be processed whenever it gets active? Do we need to
> distinguish between "Once UP" and "Whenever UP"?)
As well as the redundant IOC we do have the new iocPause and iocRun commands
which are designed to allow direct control of the running IOC; we probably
need better mechanisms for the whole pause and run issue anyway.  I am
therefor inclined to use the PINI state name RUN rather than UP, and also
have a PAUSE as well to announce that an iocPause command is happening to the
database before everything gets suspended.  I also think I should add some
more initHook phases for the whole pause/run cycle — currently the last two
hooks get announced the first time iocRun gets called, but there are no hooks
announced in iocPause or any subsequent iocRun calls.
Of course with having multiple PINI phases, what if someone wants processing
to occur in more than one phase?  Should we add combinations like YES+RUN or
RUN+PAUSE to the PINI menu item?  I say this looks ugly and probably won't be
used much; where it is needed developers will just have to have multiple
records forward-linked to kick off processing.
Bernd also replied:
> We have an additional requirement: The record code of some records need
> to know if it is processed normally, the first time at all or the first
> time after the ioc became active. Up to now we solved this problem by
> introducing a new field in those records and a function, which sets
> these fields, is registered to the redundancy task (RMT). These records
> are in a linked list. When the ioc becomes active the RMT sets the
> fields to a value, so that the record code can see that the record is
> processed first after becoming active.
A record type can always find out if this is a record's first-ever process()
call by looking at the TIME field; if it's zero (the epoch) it has never
called recGblGetTimestamp() for this record.  That distinguishes one case.
The other cases could be distinguished by making the IOC's initialization
state available, so a record type could do something like
    if (iocInitState() == iocBuilding)
to detect the processing caused by PINI=YES, and
    if (iocInitState() == iocRunning)
for the normal processing state.  It can also change the PINI field itself at
runtime if it wants to cause re-processing at one of the other events.
Would this solve your requirement?
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
Re: Local CA out links broken during PINI Schoeneburg, Bernd
Re: Local CA out links broken during PINI Andrew Johnson
Re: Local CA out links broken during PINI Ralph Lange
Prev: Re: Local CA out links broken during PINI Schoeneburg, Bernd
Next: Re: Local CA out links broken during PINI Tim Mooney
Index: 2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Local CA out links broken during PINI Schoeneburg, Bernd
