Thanks Andrew,
instead of the README I was only reading the RULES_DIRS file itself
which says (at the beginning of the block that produces the error)
# Only works with GNU make 3.80 or later (uses eval function)
So I thought I was fine - but I wasn' t.
Cheers,
Ralph
On 23.04.2009 17:11 Andrew Johnson wrote:
Hi Ralph,
On Thursday 23 April 2009 09:45:05 Ralph Lange wrote:
I'm trying to compile 3.14.10 on a native (non-cygwin) WinXP SP3 using
VisualC++ 2005 Express / Windows 2003 Server SDK R2 and mingw GNU make
3.80.
^^^^ There's your problem, you need 3.81 minimum for R3.14.10 (see README
file). It is available for mingw:
C:\epics\base3-14>make --version
GNU Make 3.81
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
This program built for i686-pc-mingw32
HTH,
- Andrew
- 3.14.10 on native win32: make problem Ralph Lange
- Re: 3.14.10 on native win32: make problem Andrew Johnson
Re: Failing EPICS Test Harness on RTEMS-mvme5500 Ralph Lange
<2009>
2025
2026
Re: some field definitions Andrew Johnson
<2009>
2025
2026
