Having a well defined mapping between bits and libraries would make it
easy to mask out status messages and alarms, so this looks like a good
idea.
I'm sure the alarm handling people will be interested in this, and have
probably thought about it before.
I would add a STS_K_DEBUG to that list, and then possibly use bits 6 and
7 for level of debug (low, medium, high).
Benjamin Franksen's email about run time extendability of alarm strings
might be a better way to go long term, in terms of adding alarms/strings
at runtime by new software.
Cheers,
Matthew
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Rees, NP (Nick)
> Sent: 03 July 2009 17:43
> To: [email protected]
> Subject: Message values and message texts.
> Hi All,
> It being Friday afternoon, I have decided to send out a
> message on this
> subject that I've been meaning to send for some time.
> Currently, as I understand it EPICS has a problem relating to status
> numbers and messages. EPICS base has status values in libraries
> consisting of a 32 bit integer where:
> - most significant 16 bits is the library modifier code
> - least significant 16 bits is the status value within that library.
> These status values have comments in the header files associated with
> them, but these ASCII comments are of no use to any software.
> Also, within records of the database there are 22 fixed status values
> defined and 4 associated severities. These do have text
> associated with
> them, but only minimal text.
> Back in the bad old days, VMS had a message system that users
> could also
> use. This provided a mechanism of accessing message numbers and
> associated text strings via a system library. The system also
> provided a
> way of generating an object file which could be linked in with any
> program which would automagically augment the system status
> values with
> user defined status values and messages.
> The 32 bit message number was divided up as follows:
> Bits 0-2: The severity, as follows
> Symbol Value Description
> STS_K_WARNING 0 Warning
> STS_K_SUCCESS 1 Success
> STS_K_ERROR 2 Error
> STS_K_INFO 3 Informational
> STS_K_SEVERE 4 Severe (Fatal) error
> 5 Reserved
> 6 Reserved
> 7 Reserved
> Bits 3-14: Message number (1-4095)>
> Bit 15: Reserved, must be set true
> Bits 16-26: Facility system number (i.e. library identifier)> Bit
27:
> Bits 28-32: Reserved, must be set false
> Now this generated an incomprehensible number, but there was a library
> routine to turn it into a string.
> In a previous life, I used a system called DRAMA, which had a library
> and set of utility programs that basically replicated this
> functionality
> for Unix and VxWorks systems. There are two problems:
> - There has to be some way of assigning Facility numbers (so
> they don't
> clash). This is an issue, but manageable.
> - Every client that wants to turn a number into a string has to have
> access to a site specific object file that has all the strings in it.
> This has to be routinely regenerated as people add more libraries and
> messages. At my last site we had a script that walked the CVS
> repository
> and dragged out all the message files on a regular basis.
> What do people think of this as an approach? Does it solve any of our
> problems? I could easily dust off the Drama message facility.
> If people
> are interested go to:
> - http://www.aao.gov.au/drama/html/mess_routines.frames.html
> - http://www.aao.gov.au/drama/html/mess_programs.frames.html
> - http://www.aao.gov.au/drama/doc/ps/mess_6.ps
> Cheers,
> Nick Rees
> Principal Software Engineer Phone: +44 (0)1235-778430
> Diamond Light Source Fax: +44 (0)1235-446713
> Scanned by iCritical.
- Message values and message texts. Rees, NP (Nick)
Base Release 3.14.11 Timetable Andrew Johnson
<2009>
2025
2026
<2009>
2025
2026
