2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA Priority for PV Gateway
To: "Ernest L. Williams Jr." <[email protected]>
Cc: Core-Talk <[email protected]>
Date: Tue, 21 Jul 2009 16:28:52 -0400
This is a non-trivial and somewhat delicate issue.
Andrew is right: If a certain gateway's priority should be higher or lower than other clients' priorities strictly depends on your system design. For a gateway to the outside world you would want a low priority to minimize impact on your IOCs, for a gateway to the control room, you would want the priority to be somewhat higher.
I would also say that adding a command line option to replace the hard-coded setting would be the next best step.
Priority by channel? I don't know. The priority sets the task priorities for the TCP task pair on the server (IOC) side. which is only one pair per client. So - does CA even allow different priorities between one client and the IOC? (I don't think so, but I might be wrong.) Even if it did, what should the gateway do if ten different clients ask for the same channel with ten different priorities? Average? Take the lowest? The highest? Open ten connections? We have to find the right compromise for the gateway between transparency, performance, and security.
Best regards from my vacation (it's a rainy day, though),
Ralph
Andrew Johnson wrote:
Hi Ernest,
On Tuesday 21 July 2009 11:29:37 Ernest L. Williams Jr. wrote:
Shouldn't connection that the PV gateway has to IOCs be attached with a
high CA Priority?
Not necessarily, that probably depends on the design of your control system. If you only have OPI connections coming through the gateway the current setting is probably right.
How do we change this?
The priority of any CA channel connection is controlled by the client when it connects to the PV, so the gateway could request a higher priority for the channels on its client-side if it was coded to do so. However both the calls to ca_create_channel() in the gateway code currently specify the fixed value CA_PRIORITY_DEFAULT for their priority. Note that changing the priority of your clients can have undesirable effects within the IOCs though if you're not careful.
One quick way to raise the priority of your gateway channels would be to rebuild the gateway to use something like CA_PRIORITY_ARCHIVE instead, although this would then affect all PVs on all IOCs that the gateway connects to.
Better solutions might be to add a command-line argument to configure that fixed value (similar to the -p <prio> option Ralph recently added to the caget, caput, camonitor and cainfo programs in Base), or even to make it controllable through the gateway's configuration file on a per-channel (regexp) basis.
I believe CosyLab has experience in making changes to the gateway code if you don't have any effort available to do that in-house.
- Andrew
Re: CA Priority for PV Gateway Ernest L. Williams Jr.
Re: CA Priority for PV Gateway Andrew Johnson
Prev: Re: CA Priority for PV Gateway Andrew Johnson
Next: Re: CA Priority for PV Gateway Ernest L. Williams Jr.
Index: 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
