Hi Ernest,
On Tuesday 21 July 2009 11:29:37 Ernest L. Williams Jr. wrote:
> Shouldn't connection that the PV gateway has to IOCs be attached with a
> high CA Priority?
Not necessarily, that probably depends on the design of your control system.
If you only have OPI connections coming through the gateway the current
setting is probably right.
> How do we change this?
The priority of any CA channel connection is controlled by the client when it
connects to the PV, so the gateway could request a higher priority for the
channels on its client-side if it was coded to do so. However both the calls
to ca_create_channel() in the gateway code currently specify the fixed value
CA_PRIORITY_DEFAULT for their priority. Note that changing the priority of
your clients can have undesirable effects within the IOCs though if you're
not careful.
One quick way to raise the priority of your gateway channels would be to
rebuild the gateway to use something like CA_PRIORITY_ARCHIVE instead,
although this would then affect all PVs on all IOCs that the gateway connects
to.
Better solutions might be to add a command-line argument to configure that
fixed value (similar to the -p <prio> option Ralph recently added to the
caget, caput, camonitor and cainfo programs in Base), or even to make it
controllable through the gateway's configuration file on a per-channel
(regexp) basis.
I believe CosyLab has experience in making changes to the gateway code if you
don't have any effort available to do that in-house.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
- Re: CA Priority for PV Gateway Ralph Lange
- RE: CA Priority for PV Gateway Jeff Hill
Re: Base R3.14.11-pre1 available for testing Eric Norum
<2009>
2025
2026
Re: Base R3.14.11-pre1 available for testing Andrew Johnson
<2009>
2025
2026
