2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Base R3.14.11-pre1 available for testing
To: "Abbott, MG (Michael)" <[email protected]>
Cc: [email protected]
Date: Fri, 31 Jul 2009 15:26:19 -0500
On Friday 31 July 2009 13:56:10 Abbott, MG (Michael) wrote:
> Actually, I just use `make` to build, but I specify my list of valid
> BUILD_ARCH targets in configure/CONFIG.
I don't think you've been using/configuring the build system quite correctly,
which is probably why you've had some difficulties with it.
You should never set BUILD_ARCHS in your applications, it's an internal
variable computed by the build system from your settings for
CROSS_COMPILER_TARGET_ARCHS and CROSS_COMPILER_HOST_ARCHS.
> Sorry, just going on holiday for a week, so don't have time to respond
> properly to your solution.
> Have to say I don't like it, think you've broken the make system.  Not
> being able to specify target builds is really not clever, and at first
> glance your workarounds sound very cumbersome -- but I'll have a proper
> look week after next.  Do you have time to look at my build:
> http://controls.diamond.ac.uk/downloads/libera ?  I've tried to make the
> configure and Makefiles as clear and simple as I can, but the EPICS build
> is always full of mysteries for me.
I will take a look at the libera build configuration in detail over the next
week or so and send you some changes to make it do what you need within the
R3.14.11 (and earlier) rules.  We should be able to resolve this without
resorting to pistols at dawn...
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
RE: Base R3.14.11-pre1 available for testing Abbott, MG (Michael)
Prev: RE: Base R3.14.11-pre1 available for testing Abbott, MG (Michael)
Next: mantis 354 - ca_host_name returns empty string if dns server hasnt responded yet? Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: CA Priority for PV Gateway Andrew Johnson
