Hi Babak,
On Friday 14 August 2009 05:31:55 Kalantari Babak wrote:
> I have a question regarding the vxWorks time driver of generalTime
> (drvDevVWTime.c) which we use in EPICS 3.14.8 and mv2304/mv5500.
We don't use that here, so there's not be much I can say about it...
> Shouldn't the VWTime (for systems with vxWorks OS) be always available
> even if it is not synced? (It could at least be set to EPICS epoch.)
> Is it also like this in 3.14.10 after changes in generalTime?
This is the code from osiClockTime.c in R3.14.11 which deals with this case:
/* Time Provider Routine */
static int ClockTimeGetCurrent(epicsTimeStamp *pDest)
struct timespec clockNow;
/* If a Hi-Res clock is available and works, use it */
#ifdef CLOCK_REALTIME_HR
clock_gettime(CLOCK_REALTIME_HR, &clockNow) &&
#endif
clock_gettime(CLOCK_REALTIME, &clockNow);
if (!ClockTimePvt.synchronized &&
clockNow.tv_sec < POSIX_TIME_AT_EPICS_EPOCH) {
clockNow.tv_sec = POSIX_TIME_AT_EPICS_EPOCH + 86400;
clockNow.tv_nsec = 0;
clock_settime(CLOCK_REALTIME, &clockNow);
errlogPrintf("WARNING: OS Clock time was read before being set.\n"
"Using 1990-01-02 00:00:00.000000 UTC\n");
epicsTimeFromTimespec(pDest, &clockNow);
return 0;
Thus if still unsynchronized it will print a warning message the first time
you try and read it and set the clock to 1990-01-02T00:00:00.0Z which is
guaranteed to be after the EPICS epoch no matter what timezone you're in.
> The other issue is RTC:
> It seems that vxWorks clockLib (clock_gettime, clock_settime, ...) does
> not make use of on-board RTC. If I call clock_gettime() after a soft
> reboot it always starts from 0 while the RTC should run at least as long
> as there is power. Wouldn't it be better to use RTC to maintain time
> sources like VWTime?
Not by default since vxWorks runs on boards that don't have an RTC, and we
also want things to continue working even if the RTC battery dies. However
the nice thing about the plugin architecture we now have is that you can
write a time provider plugin that knows how to access the RTC for your
particular board, and your vxWorks clock will then get synchronized to the
RTC if you do this.
Note that there is no standard RTC interface in the vxWorks BSPs, so you will
probably have to write a different one for each CPU board. This code can be
as clever as you like, including synchronizing the RTC to higher priority NTP
sources and even measuring how good the RTC is and correcting for a measured
slow or fast oscillator.
HTH,
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
- VWTime driver Kalantari Babak
proper thread cleanup on Linux? Jeff Hill
<2009>
2025
2026
<2009>
2025
2026
