2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: FW: StreamDevice bug
To: [email protected]
Cc: [email protected], [email protected]
Date: Mon, 15 Feb 2010 12:05:23 -0600
On Monday 15 February 2010 10:53:56 [email protected] wrote:
> In a recent exchange between Dirk and us about streamDevice, Dirk
> pointed out one way in which stringout is different to other base output
> records - it won't call device support if UDF is true.
> Is this deliberate or a bug? If it is a bug, should we fix it because it
> will result in a behaviour change?
There is a bug there, but the idea that the other record types always call
device support even with UDF true is not quite right; they don't directly
check UDF in process, but have checkAlarms() set prec->nsev to INVALID_ALARM
when UDF is true and make the record's behaviour in the presence of an
INVALID_ALARM depend on the setting of prec->ivoa.
> I can see a viable argument that the opposite should be true - device
> support shouldn't be called if UDF is true. A third alternative is that
> the  decision should be deferred to device support.
I think the other records have it right, what should happen is controlled by
the database designer using IVOA.  In the case of stringout though, I think
the 'goto finish' line needs to be deleted to allow the IVOA mechanism (which
is already present in the process() routine) to work properly.
> I know stringout is different to other standard output records because
> constant links can't be strings, because strings resolve as db or CA
> links. The workaround is to put the string into VAL and make OMSL
> supervisory. This should actually solve our problem (because UDF won't
> be true anymore), but I was wondering whether there was any reasoning
> behind the current implementation.
Not that I can think of, and looking at the history it got changed to this by
Marty back in 1996 when an even worse bug in it was fixed.
If there are no objections I propose to apply the following patch:
=== modified file 'src/rec/stringoutRecord.c'
--- src/rec/stringoutRecord.c   2009-07-08 18:14:11 +0000
+++ src/rec/stringoutRecord.c   2010-02-15 17:57:30 +0000
@@ -145,7 +145,6 @@
         if(prec->udf == TRUE ){
                 recGblSetSevr(prec,UDF_ALARM,INVALID_ALARM);
-                goto finish;
         if (prec->nsev < INVALID_ALARM )
@@ -172,7 +171,7 @@
        /* check if device support set pact */
        if ( !pact && prec->pact ) return(0);
-finish:
        prec->pact = TRUE;
        recGblGetTimeStamp(prec);
        monitor(prec);
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
FW: StreamDevice bug nick.rees
Prev: FW: StreamDevice bug nick.rees
Next: dbToRecordTypeH Benjamin Franksen
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
