Subject: |
[Bug 541396] Re: initialize VAL of an mbbi/o record with a string |
Andrew Johnson <[email protected]> |
To: |
[email protected] |
Date: |
Fri, 26 Mar 2010 15:02:22 -0000 |
Would it be acceptable to do this through a constant string in the
mbbo.DOL link instead of by setting VAL?
I can see this could be made to work if there were a new kind of
constant link that can support non-numeric constants, including arrays,
since as Ben suggests a PV link doesn't actually parse the string until
iocInit() time.
This actually happens to be an area I've been working on in the last
couple of weeks, and I suspect this ability might fall out of my work,
so I'll see if I can implement something like it. I'm guessing it may
need changes to the record type code, but that's not certain right now.
** Changed in: epics-base
Assignee: (unassigned) => Andrew Johnson (anj)
Status: Confirmed => Triaged
https://bugs.launchpad.net/bugs/541396
You received this bug notification because you are a member of EPICS
Core Developers, which is a direct subscriber.
Status in EPICS Base: Triaged
Bug description:
With the following record in a db file
record(mbbo,"TEST:mbbo") {
field(VAL,"Zero")
field(ZRST,"Zero")
field(ONST,"One")
I get
dbLoadRecords("test.db", "")
Error Last token ")"
input line: field(VAL,"Zero")
in: path "." file test.db line 2
I think it would be nice to be able to initialize an mbbo or mbbi record with one of the configured string values.
Original Mantis Bug: mantis-373
http://www.aps.anl.gov/epics/mantis/view_bug_page.php?f_id=373
- Re: [Bug 541396] Re: initialize VAL of an mbbi/o record with a string Benjamin Franksen
[Bug 541396] Re: initialize VAL of an mbbi/o record with a string Andrew Johnson
<2010>
2025
2026
<2010>
2025
2026
