Subject: |
[Bug 541396] Re: initialize VAL of an mbbi/o record with a string |
Andrew Johnson <[email protected]> |
To: |
[email protected] |
Date: |
Fri, 26 Mar 2010 14:57:47 -0000 |
Comment from Tim Mooney:
I can't tell from context exactly what problem is being discussed, but
it seems like you could take an exploratory stab, at some of what you'd
like to do, using info nodes.
I'm imagining you would modify a record's init_record() routine to parse
the record's info node(s), looking for a specially named or defined node
to indicate a field that needs a lazy load, and the data that should be
loaded. This would allow you to make at least some progress without
waiting for any (other) changes in base.
https://bugs.launchpad.net/bugs/541396
You received this bug notification because you are a member of EPICS
Core Developers, which is a direct subscriber.
Status in EPICS Base: Triaged
Bug description:
With the following record in a db file
record(mbbo,"TEST:mbbo") {
field(VAL,"Zero")
field(ZRST,"Zero")
field(ONST,"One")
I get
dbLoadRecords("test.db", "")
Error Last token ")"
input line: field(VAL,"Zero")
in: path "." file test.db line 2
I think it would be nice to be able to initialize an mbbo or mbbi record with one of the configured string values.
Original Mantis Bug: mantis-373
http://www.aps.anl.gov/epics/mantis/view_bug_page.php?f_id=373
Re: [Bug 541396] Re: initialize VAL of an mbbi/o record with a string Tim Mooney
[Bug 541396] Re: initialize VAL of an mbbi/o record with a string Andrew Johnson
<2010>
2025
2026
<2010>
2025
2026
