2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: VAL keyword in calcout records
To: EPICS Core Talk <[email protected]>
Date: Mon, 12 Apr 2010 18:12:45 -0400
I just learned that the recently introduced VAL keyword does not (quoting the Record Reference Manual) return "the current contents of the VAL field" but rather "the current contents of this expression's result".
Which means, that inside a calcout record's OCAL expression, VAL refers to OVAL, not VAL. Which means you can not use VAL inside OCAL to refer to the result of the CALC expression, but have to repeat the CALC expression inside OCAL to get the same value.
Which (in my case) makes the OCAL expression more than 40 characters long, which doesn't work.
Should we change the behaviour or the documentation?
Ralph
Re: VAL keyword in calcout records Andrew Johnson
Prev: RE: missing monitors Davidsaver, Michael
Next: Re: VAL keyword in calcout records Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: naming the operating system independence layer Jeff Hill
