2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VAL keyword in calcout records
To: [email protected]
Date: Mon, 12 Apr 2010 17:43:51 -0500
On Monday 12 April 2010 17:12:45 Ralph Lange wrote:
> I just learned that the recently introduced VAL keyword does not
> (quoting the Record Reference Manual) return "the current contents of
> the VAL field" but rather "the current contents of this expression's
> result".
That sentence was obviously written assuming that the result would be assigned
to the VAL field, which was always true for the Calc record but not for the
Calcout.  The VAL keyword could be added because calcPerform() takes a pointer
to the double where it should put the result, so it assumes that the previous
value is still available.
> Which means, that inside a calcout record's OCAL expression, VAL refers
> to OVAL, not VAL.
> Which means you can not use VAL inside OCAL to refer to the result of
> the CALC expression, but have to repeat the CALC expression inside OCAL
> to get the same value.
> Which (in my case) makes the OCAL expression more than 40 characters
> long, which doesn't work.
If you have a spare input and enough space in the CALC expression you could
assign the CALC result to that variable using the := operator, then it will be
available to use in your OCAL expression:
CALC: L:=<expression>;L
OCAL: <expression using L>
> Should we change the behaviour or the documentation?
My first though was that we have to change the documentation of the Calcout
record, but I guess it would be possible to assign prec->oval = prec->val
before evaluating OCAL.  However if someone does understand how the VAL
keyword works they might already be relying on the existing behaviour.
I think I'd be happier just fixing the documentation.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
VAL keyword in calcout records Ralph Lange
Prev: VAL keyword in calcout records Ralph Lange
Next: 64-bit Windows architecture support in EPICS Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
