Hi Mark,
On Monday 26 April 2010 11:59:30 Mark Rivers wrote:
> No, I just learned about that in a message from Janet this morning. It
> is not mentioned in the EPICS release notes or in the
> README/Installation file that describes the supported architectures. I
> had not looked in the configure/os directory.
I'm guessing that it might not have been ready for operational use or fully
tested at the time of the R3.14.11 release, hence Janet didn't document it
then.
> I'm a little confused over the correct name for this new architecture.
> The file is called
> /configure/os/CONFIG.windows-x64.windows-x64
> That makes it sound like the architecture is windows-x64. But in that
> file it uses a different syntax in the comments, win-x86_64. What do I
> set EPICS_HOST_ARCH to?
Janet has changed those names in the comments now, the proper architecture
name is windows-x64. There's some background on the naming of the x86-64
processor architecture at http://en.wikipedia.org/wiki/X86-64 which mentions
that this was AMD's original name for it, but they now use AMD64 and Intel
call their version INTEL64. It's becoming common to call it X64.
Janet's commit since the R3.14.11 release can be seen at
http://bazaar.launchpad.net/~epics-core/epics-base/3.14/revision/12006 and
does seem to have some significant changes in it, in addition to allowing for
cross-compilation by a 32-bit machine.
HTH,
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- 64-bit Windows architecture support in EPICS Mark Rivers
- Re: 64-bit Windows architecture support in EPICS Andrew Johnson
- RE: 64-bit Windows architecture support in EPICS Mark Rivers
Experimental Sequencer Release Benjamin Franksen
<2010>
2025
2026
<2010>
2025
2026
