2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: 64-bit Windows architecture support in EPICS
To: "Andrew Johnson" <[email protected]>, <[email protected]>, <[email protected]>
Date: Mon, 26 Apr 2010 11:59:30 -0500
Hi Andrew,
> The 3.14 branch does currently contain support for a host architecture
> "windows-x64" which Janet added in February 2009 and modified in
October
> (after then R3.14.11 release).  Have you tried this yet?
No, I just learned about that in a message from Janet this morning.  It
is not mentioned in the EPICS release notes or in the
README/Installation file that describes the supported architectures. I
had not looked in the configure/os directory.
I'm a little confused over the correct name for this new architecture.
The file is called
/configure/os/CONFIG.windows-x64.windows-x64
That makes it sound like the architecture is window-x64.  But in that
file it uses a different syntax in the comments, win-x86_64.  What do I
set EPICS_HOST_ARCH to?
# CONFIG.win-x86_64.win-x86_64
# $Id: CONFIG.windows-x64.windows-x64,v 1.1.2.1 2009/02/26 20:56:53 jba
Exp $
# This file is maintained by the build community.
# Definitions for win-x86_64 target archs when host arch is win-x86_64
# Sites may override these definitions in
CONFIG_SITE.win-x86_64.win-x86_64
-----Original Message-----
Sent: Monday, April 26, 2010 11:30 AM
To: [email protected]; [email protected]
Cc: Mark Rivers; [email protected]
Subject: Re: 64-bit Windows architecture support in EPICS
Hi Mark,
On Saturday 24 April 2010 10:27:57 Mark Rivers wrote:
> I am starting to really need support for 64-bit Windows on EPICS.
Many of
> our new desktop machines are running Windows 7 64-bit, and I want to
run
> both EPICS extensions (e.g. medm) and IOCs (e.g. Prosilica cameras) on
> these machines.  Has anyone developed the required files in
> base/configure/os for 64-bit Windows support?  I don't think Cygwin
yet has
> 64-bit support, but the Microsoft compiler does of course.  I've built
> 64-bit non-EPICS applications on Windows already using the Microsoft
> compiler.
"windows-x64" which Janet added in February 2009 and modified in October
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Re: 64-bit Windows architecture support in EPICS Andrew Johnson
64-bit Windows architecture support in EPICS Mark Rivers
Prev: Re: 64-bit Windows architecture support in EPICS Andrew Johnson
Next: Re: 64-bit Windows architecture support in EPICS Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
