On Fri 14 May 2010 13:54:10 Ben Franksen wrote:
I am astonished. Does Bazaar not have an equivalent of 'darcs unrecord'?
It does: 'bzr uncommit'
Bazaar will only be able to uncommit from the latest commit backwards to
a specified revision, as opposed to Darcs that lets you unrecord *any*
set of patches.
Or is it rather that you are using the central shared repository for
synchronizing home/office work? This is probably not such a good idea. I'd
advise to push and pull (or whatever the equivalent operations are named in
Bazaar) from your home machine to some private repo (clone) on your office
workstation. Being able to do so is one of the main reasons why distributed
VCSes have been invented in the first place.
Things might be more complicated when the office workstation is not
accessible from home (I know that LANL security is somewhat strict),
still a private Bazaar branch on LP could be used that way.
As I think about this, maybe it would be worthwhile to consider a different
approach for EPICS base: send patches via email instead of directly pushing
to the main shared repo. This is certainly less convenient, but would
enable others to review the changes before they get committed to the main
repo.
The current approach for EPICS Base is: develop in a public branch, then
use the Launchpad supported mechanism for reviewing a branch before it
gets merged into the trunk or release branch. I think that workflow is
appropriate.
(See the good explanation of things on the EPICS Wiki [1].)
Cheers,
Ralph
[1]
http://www.aps.anl.gov/epics/wiki/index.php/How_to_check_out_EPICS_Base_with_Bazaar
- Re: [Merge] lp:~ralph-lange/epics-base/ca-over-tcp into lp:epics-base Benjamin Franksen
- Re: [Merge] lp:~ralph-lange/epics-base/ca-over-tcp into lp:epics-base Jeff Hill
- Re: [Merge] lp:~ralph-lange/epics-base/ca-over-tcp into lp:epics-base Ben Franksen
Re: [Merge] lp:~ralph-lange/epics-base/ca-over-tcp into lp:epics-base Andrew Johnson
Re: [Merge] lp:~ralph-lange/epics-base/ca-over-tcp into lp:epics-base Ralph Lange
<2010>
2025
2026
<2010>
2025
2026
