Hi Ron
On Friday 21 May 2010, Chestnut, Ronald P. wrote:
> Dear Nesknarf,
> As a person whose favorite hammer is, indeed, SNL, this led me to think
> about my many programs and whether this has ever been of consequence.
> The answer is "I think not". I've always used integer values as triggers
> for state transitions, and compared carefully if the actual value, (and
> not just a change which triggered a state transition), was important. If
> some value is critical, I copy it and use the copy, so that I have the
> monitored value which triggered the transition and not a later monitored
> value.
> Lots of code looks like:
> When (monitored_value != Stored_value) {
> Stored_value=monitored_value;
> Use Stored_value in all code here
> I realize that there is a short time hole in this too, but I can't
> remember having been bitten by it.
As I said, it is very unlikely to happen in typical programs. But it still
may happen, and if it does you're screwed.
> One could simply generate a warning if a string or array (or any
> non-atomic thing -- perhaps a double on some architectures) is not safe;
> if the programmer knows that only operator-time-scale actions
> precipitate a new value, this warning could be ignored; if not, change
> the logic to use an atomic trigger.
You are, of course, free to bury you head in the sand and ignore the
problem. This won't make it go away, though.
> So my take is that this is a small problem. Finding an elegant solution
> would be really neat, but not finding it is not a show stopper.
My primary objective is to find a solution that is safe and reliable. I
think this can be done at a slight cost in runtime performance and
compatibility.
The runtime cost is that each monitored variable has to be copied from an
internal buffer, whenever a state set wakes up and checks state change
conditions and a callback has happened in the meantime.
The cost in compatibility is that changes to a variable (due to monitors)
will never be seen by the program, except when it waits for events. I think
this would be acceptable, as I cannot imagine there are lots of programs
that *rely* on monitored variables changing *during* executution of an SNL
statement block.
Cheers
Ben
- Race conditions in SNL programs Benjamin Franksen
[Merge] lp:~khkim/epics-base/fix-572589 into lp:epics-base Andrew Johnson
<2010>
2025
2026
<2010>
2025
2026
