2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: [Merge] lp:~dirk.zimoch/epics-base/DTYP-parsing into lp:epics-base
To: [email protected]
Date: Sun, 30 May 2010 12:16:26 -0000
Dirk Zimoch has proposed merging lp:~dirk.zimoch/epics-base/DTYP-parsing into lp:epics-base.
Requested reviews:
  EPICS Core Developers (epics-core)
Now INP/OUT and DTYP can be defined in any order. The original text of INP/OUT link is stored and re-parsed later if DTYP changes.
https://code.launchpad.net/~dirk.zimoch/epics-base/DTYP-parsing/+merge/26381
Your team EPICS Core Developers is requested to review the proposed merge of lp:~dirk.zimoch/epics-base/DTYP-parsing into lp:epics-base.
=== modified file 'documentation/RELEASE_NOTES.html'
--- documentation/RELEASE_NOTES.html	2010-04-26 22:16:06 +0000
+++ documentation/RELEASE_NOTES.html	2010-05-30 12:16:26 +0000
@@ -12,6 +12,10 @@
 <h2 align="center">Changes between 3.14.11 and 3.14.12</h2>
 <!-- Insert new items immediately below here ... -->
+<h4>DTYP and INP/OUT order</h4>
+<p>The fields DTYP and INP/OUT can now be specified in any order.
 <h4>Rewrite epicsThreadOnce()</h4>
 <p>Michael Davidsaver suggested a better implementation of epicsThreadOnce()
=== modified file 'src/dbStatic/dbStaticLib.c'
--- src/dbStatic/dbStaticLib.c	2009-08-03 22:22:45 +0000
+++ src/dbStatic/dbStaticLib.c	2010-05-30 12:16:26 +0000
@@ -277,6 +277,19 @@
     plink = (DBLINK *)pdbentry->pfield;
     if (plink->type == link_type) goto done;
+    if (plink->text)
+        /* re-parse link text when DTYP has changed */
+        char * link_text;
+        link_text = plink->text;
+        plink->text = NULL;
+        dbFreeLinkContents(plink);
+        plink->type = link_type;
+        dbPutString(pdbentry, link_text);
+        free(link_text);
+        goto done;
     type = plink->type;
     if ((type == CONSTANT || type == PV_LINK || type == DB_LINK || type == CA_LINK) &&
 	(link_type == CONSTANT || link_type == PV_LINK)) goto done;
@@ -331,6 +344,7 @@
 	     epicsPrintf("dbFreeLink called but link type unknown\n");
     if(parm && (parm != pNullString)) free((void *)parm);
+    if(plink->text) free(plink->text);
     memset((char *)plink,0,sizeof(struct link));
@@ -2224,6 +2238,8 @@
 		    errMessage(status,"in dbPutString from setLinkType");
 		    return status;
+                /* store link text in case DTYP changes later */
+                plink->text = epicsStrDup(pstring);
 	    if (strlen(pstring) >= sizeof(string)) {
 	        status = S_dbLib_badField;
=== modified file 'src/dbStatic/link.h'
--- src/dbStatic/link.h	2009-04-03 20:54:00 +0000
+++ src/dbStatic/link.h	2010-05-30 12:16:26 +0000
@@ -183,6 +183,7 @@
 struct link{
 	union value	value;
 	short		type;
+        char		*text;		/* original INP/OUT link text */
 typedef struct link DBLINK;
Prev: Re: [Merge] lp:~khkim/epics-base/alarm-filter into lp:epics-base Ralph Lange
Next: Hacking rsrv/camessage.c Michael Abbott
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
