2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Hacking rsrv/camessage.c
To: EPICS core <[email protected]>, Jeff Hill <[email protected]>
Date: Wed, 2 Jun 2010 07:30:42 +0100 (BST)
I'm in the middle of reworking read_reply() (rsrv/camessage.c) to
implement support for autoresizing arrays (I hope to post my patches later
this week), and I've encountered a curious bit of special case code that
I'm about to erase ... so thought I'd better ask about it.
I'm puzzled by this commit (I've edited out all the rest of the diff, as
it doesn't affect my changes):
revno: 10992
committer: Jeff Hill <[email protected]>
branch nick: B3.14
timestamp: Fri 2007-09-07 17:43:52 +0000
message:
  fix for mantis entry 300:
  'assert (size <= ntohs ( pMsg->m_postsize ))' failed in ..caserverio.c line 344
diff:
=== modified file 'src/rsrv/camessage.c'
--- src/rsrv/camessage.c        2007-08-17 22:31:11 +0000
+++ src/rsrv/camessage.c        2007-09-07 17:43:52 +0000
@@ -586,16 +598,25 @@
             if ( pevext->msg.m_dataType == DBR_STRING
                 && pevext->msg.m_count == 1 ) {
-                /* add 1 so that the string terminator will be shipped */
-                strcnt = strlen ( (char *) pPayload ) + 1;
-                msgSize = strcnt;
+                char * pStr = (char *) pPayload;
+                size_t strcnt = strlen ( pStr );
+                if ( strcnt < payloadSize ) {
+                    payloadSize = ( ca_uint32_t ) ( strcnt + 1u );
+                else {
+                    pStr[payloadSize-1] = '\0';
+                    errlogPrintf (
+                        "caserver: read_reply: detected DBR_STRING w/o nill termination "
+                        "in response from db_get_field, pPayload = \"%s\"\n",
+                        pStr );
         else {
-            memset ( pPayload, 0, msgSize );
+            memset ( pPayload, 0, payloadSize );
             cas_set_header_cid ( pClient, cacStatus );
-        cas_commit_msg ( pClient, msgSize );
+        cas_commit_msg ( pClient, payloadSize );
I'm quite baffled.  Is there any reason not to *always* ship the entire 40
characters of the EPICS string as a matter of course?  Or is this a fine
grained optimisation to avoid shipping an extra average 20 bytes?
My patches are going to drop this block of code altogether (so really my
inquiries ought to also address the parent patches), but thought I'd
better highlight this separately!
Re: Hacking rsrv/camessage.c Andrew Johnson
RE: Hacking rsrv/camessage.c Jeff Hill
Prev: [Merge] lp:~dirk.zimoch/epics-base/DTYP-parsing into lp:epics-base Dirk Zimoch
Next: [PATCH 1/4] Client side support for automatic resizing arrays. Michael Abbott
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Hacking rsrv/camessage.c Andrew Johnson
