2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Using C++ keywords as variable names in C code
To: EPICS Core Talk <[email protected]>
Date: Wed, 16 Jun 2010 10:39:42 -0400
Hello everybody,
I found that db_access.c is using the C++ keyword "new" as a variable name. While this is of course valid code, it confuses IDEs, syntax highlighting editors and such, so I would probably consider it bad practice. Has anybody considered fixing this issue? Else I would create a branch for it and get it done. While I'm at it - any other C++ keywords I should rename? Should I enforce straight C comments instead of C++ style "//" comments, too? Or are all compilers accepting these nowadays?
Cheers,
Ralph
RE: Using C++ keywords as variable names in C code Jeff Hill
Prev: Re: [Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base Michael Abbott
Next: RE: Using C++ keywords as variable names in C code Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
