2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base
To: [email protected]
Date: Mon, 05 Jul 2010 08:59:22 -0000
Well, I've responded to Jeff's review comments.
* I've updated the version number and guard from 4.12 to 4.13.  Of course, this means that this branch really does need to be merged after the TCP-based search requests feature.
* Rather than think very hard (and maybe make a stupid mistake) I've just guarded the memset() that Jeff flagged with the obvious sanity test.
* I've re-merged with EPICS base.  As I noted on the mailing list, this introduced a massive merge conflict with the variable renaming in db_access.c, but as the renaming is quite gratuitous I simply dropped that part of the merge.
* I'm sorry, I've not done anything to acctst.c.  As far as I can see it's client side only, and I don't really see where to get started without spending a *lot* of time on it.  I'll try and look at this again another time.
https://code.launchpad.net/~michael-abbott/epics-base/dynamic-array/+merge/26796
Your team EPICS Core Developers is requested to review the proposed merge of lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base.
[Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base Michael Abbott
Prev: Re: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base Dirk Zimoch
Next: Re: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: [Merge] lp:~michael-abbott/epics-base/dynamic-array intolp:epics-base Jeff Hill
Next: Using C++ keywords as variable names in C code Ralph Lange
