Subject: |
Re: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base |
Andrew Johnson <[email protected]> |
To: |
[email protected] |
Date: |
Tue, 06 Jul 2010 14:37:22 -0000 |
On Monday 05 July 2010 03:02:23 Dirk Zimoch wrote:
> * BPTR must not change at run time (e.g. no double buffering). I have to
> check what devExtend() does to solve this problem.
Sorry, devExtend() is the way that a device support tells the iocCore code
that it can accept address changes at runtime; it doesn't solve that problem.
The devExtend() routine must be called from a dset->init() routine and points
to a dsxt structure with the add_record() and del_record() routines that
support those runtime changes for this device support. My point was merely
that if BPTR can't be changed after rset->init_record(0) returns [presumably
because this somehow stops DB links from working] that it's not going to be
possible to have extended device support that sets BPTR. Not a major issue,
and there are no incompatibilities here.
> I kept the memory allocation model to stay compatible to old device
> supports. Additionally I allow for new device supports not to set BPTR.
> Also to stay compatible, I do not want to switch from BPTR to VAL.
I agree that this is the best solution for now.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
https://code.launchpad.net/~dirk.zimoch/epics-base/fix-aai-and-aao/+merge/26195
Your team EPICS Core Developers is requested to review the proposed merge of lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base.
- Re: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base Dirk Zimoch
Re: [Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base Michael Abbott
<2010>
2025
2026
<2010>
2025
2026
