2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Merges: 3.14.12 vs 3.15
To: EPICS Core Talk <[email protected]>
Date: Thu, 24 Jun 2010 09:14:45 -0400
I completely agree with Andrew on the approach and the criteria.
What's the plan for 3.15, i.e. for releasing a 3.15.0 preview of our coming attractions? Am I right assuming that there will not be another scheduled 3.14 release after 3.14.12? (Except for maybe a bug fix bundle...)
My thoughts on the dynamic array branch decision:
For some installations the static array issue causes considerable pain. These places would have a high interest in getting this feature. Looking at the changes I see a certain chance that this feature has side effects that are yet to be found. We need something "sexy" in 3.15 to make people try and take it for a test drive.
If we manage to get out 3.15.0 this summer, I would like to see dynamic arrays in there. If 3.15.0 means next year, it should go into 3.14.12.
Just my 2 cents....
Ralph
On Wed 23 Jun 2010 18:43:45 Andrew Johnson wrote:
We currently have over 20 development branches of Base on Launchpad, 8 of which have approvable merge proposals. I see some of them as being appropriate for a 3.14.12 release, but others will have to go into 3.15.
Before discussing individual branches though, I want to talk about how we should distinguish and decide between the two. The 3.14 series is very widely used now, so upgrading to a new point release within the series should be a straight-forward process.
I hope no one is going to object to the idea that anything requiring major changes to existing IOC database applications or support modules should only be made in a major release, 3.15 (or later). I also want branches like Marty's process-get work and my compiled-dbd that involve some fairly major internal redevelopment to go into 3.15, even if they are backwards compatible.
If I understand Jeff's position correctly (correct me if I'm wrong Jeff) he says that minor releases should only contain bug fixes and no new features. IMHO though over the last few years that would have prevented the introduction of many new features to Base that have been successfully included without breaking backwards compatibility, at a time when we would not have been able to create a new major release due to partially-implemented features on the CVS main trunk.
My position is that a development should be acceptable into a minor release if it is not likely to break existing IOC database applications and it does not require major changes to existing C code (and any missing C or DBD file changes get reported at compile- or link-time). Any development that changes the meaning or use of an existing record field (other than adding new non- default options) would have to wait for the next major release. Where a feature is currently broken and effectively unusable those rules can be relaxed when fixing it in a minor release though.
Applying those principles to the current crop of merge proposals, I make the following suggestions for merge targets (assuming they all pass the code review):
            lp:~khkim/epics-base/alarm-filter       3.14.12
      lp:~ralph-lange/epics-base/ca-over-tcp        3.14.12
  lp:~ronaldo-mercado/epics-base/capr               3.14.12
      lp:~mdavidsaver/epics-base/devlib-cleanup     3.14.12
   lp:~michael-abbott/epics-base/dynamic-array      3.15
      lp:~dirk.zimoch/epics-base/fix-aai-and-aao    3.14.12
      lp:~dirk.zimoch/epics-base/named-soft-events  3.15
      lp:~dirk.zimoch/epics-base/non-val-attributes 3.15
I could probably be persuaded either way on the dynamic-array branch.
Comments please...
- Andrew
Merges: 3.14.12 vs 3.15 Andrew Johnson
Prev: RE: Merges: 3.14.12 vs 3.15 nick.rees
Next: Re: [Merge] lp:~michael-abbott/epics-base/dynamic-array intolp:epics-base Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Merges: 3.14.12 vs 3.15 Davidsaver, Michael
