2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~mdavidsaver/epics-base/devlib-pci into lp:epics-base
To: Eric Norum <[email protected]>
Date: Fri, 09 Jul 2010 20:16:42 -0000
> Which RTEMS BSPs have support for this?
It was developed and tested on an mvme3100 with RTEMS 4.9.2 and .3.  It compiles against mvme2100 and 5500, as well as pc386.  The limitation here is lack of hardware and my having only built toolchains for x86-32 and ppc.
https://code.launchpad.net/~mdavidsaver/epics-base/devlib-pci/+merge/29603
Your team EPICS Core Developers is requested to review the proposed merge of lp:~mdavidsaver/epics-base/devlib-pci into lp:epics-base.
Re: [Merge] lp:~mdavidsaver/epics-base/devlib-pci into lp:epics-base Eric Norum
Prev: Re: [Merge] lp:~mdavidsaver/epics-base/devlib-pci into lp:epics-base Eric Norum
Next: [Merge] lp:~epics-base-testing/epics-base/base-tests into lp:epics-base Jonathan Thompson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
