2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: [Merge] lp:~epics-base-testing/epics-base/base-tests into lp:epics-base
To: [email protected]
Date: Fri, 30 Jul 2010 12:24:48 -0000
Jonathan Thompson has proposed merging lp:~epics-base-testing/epics-base/base-tests into lp:epics-base.
Requested reviews:
  EPICS Core Developers (epics-core)
Additions to make files that create test case information files that allow the automatic regression test system to find the test cases to be run.  Merging these to trunk will allow the automatic regression test system to be run on trunk.
https://code.launchpad.net/~epics-base-testing/epics-base/base-tests/+merge/31370
Your team EPICS Core Developers is requested to review the proposed merge of lp:~epics-base-testing/epics-base/base-tests into lp:epics-base.
=== modified file 'configure/RULES_BUILD'
--- configure/RULES_BUILD	2010-07-29 19:58:14 +0000
+++ configure/RULES_BUILD	2010-07-30 12:24:48 +0000
@@ -89,6 +89,13 @@
 PRODTARGETS += $(PRODNAME) $(MUNCHNAME) $(CTDT_SRCS) $(CTDT_OBJS) $(NMS)
+#   Generate a test specification if any tests are defined.
+ifneq (,$(strip $(TESTS)))
+TARGETS+=testspec
+endif
 #   Libraries
@@ -315,6 +322,13 @@
 runtests: $(TESTSCRIPTS_$(BUILD_CLASS))
 	-$(PERL) -MTest::Harness -e 'runtests @ARGV if @ARGV;' $^
+testspec: $(TESTSCRIPTS_$(BUILD_CLASS))
+	@$(RM) $@
+	@echo OS-class: $(OS_CLASS) > $@
+	@echo Target-arch: $(T_A) >> $@
+	@echo Tests: $^ >> $@
+	$(if $(TESTSPEC_$(OS_CLASS)), @echo "Harness: $(TESTSPEC_$(OS_CLASS))" >> $@)
 # If there's a perl test script (.plt) available, use it
 %.t: ../%.plt
 	@$(RM) $@
=== modified file 'src/libCom/test/Makefile'
--- src/libCom/test/Makefile	2010-05-05 20:43:58 +0000
+++ src/libCom/test/Makefile	2010-07-30 12:24:48 +0000
@@ -142,11 +142,12 @@
 PROD_vxWorks = vxTestHarness
 vxTestHarness_SRCS += $(testHarness_SRCS)
 vxTestHarness_OBJS += $(INSTALL_BIN)/vxComLibrary
+TESTSPEC_vxWorks = vxTestHarness.munch; epicsRunLibComTests
 PROD_RTEMS += rtemsTestHarness
 rtemsTestHarness_SRCS += rtemsTestHarness.c
 rtemsTestHarness_SRCS += $(testHarness_SRCS)
+TESTSPEC_RTEMS = rtemsTestHarness.boot; epicsRunLibComTests
 TESTSCRIPTS_HOST += $(TESTS:%=%.t)
Prev: Re: [Merge] lp:~mdavidsaver/epics-base/devlib-pci into lp:epics-base mdavidsaver
Next: some issues with "lp:epics-base" in bazaar Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
