2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: some issues with "lp:epics-base" in bazaar
To: "'Andrew Johnson'" <[email protected]>
Cc: "'EPICS Core Talk'" <[email protected]>
Date: Fri, 13 Aug 2010 15:26:27 -0600
Hi Andrew,
I found two significant bugs in base today, and if I fix them only on my cvs
main trunk ancestor branch there is a risk that they will be lost when
attempting to break that tree into independent merges. So I tried to refresh
my existing R3.14 development area. That didn?t work so I threw out that one
and tried to load a fresh one but there are still some issues.
In any case when I try to download from the URL "lp:epics-base" using bazaar
explorer I see the error message below. I think this worked before, but
perhaps I am doing something stupid? In any case loading code from
"https://code.launchpad.net/epics-base"; does work just fine.
Invalid url supplied to transport:
"file:///home/phoebus3/ANJ/epics/base/export/base.bzr/trunk/": Win32 file
urls start with file:///x:/, where x is a valid drive letter
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: Correspondence
Re: some issues with "lp:epics-base" in bazaar Andrew Johnson
Prev: [Merge] lp:~epics-base-testing/epics-base/base-tests into lp:epics-base Jonathan Thompson
Next: Re: some issues with "lp:epics-base" in bazaar Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
