Hi Ralph,
On Monday 16 August 2010 11:03:10 Ralph Lange wrote:
> it looks as I have found the reason for the segfaults, which I think is
> a bug in CAC.
Yay!
Does this fix need to be applied to earlier versions of CAC, or just to the
code since merging with ca-over-tcp? I'm wondering whether it should become a
Known Problem in 3.14.11 or not.
> This one-line fix will take care of the problem:
It certainly solves the segfault issue I was having with the head of the 3.14
branch, thanks!
I will apply this and the other patch you sent directly to the 3.14 branch.
The ca-over-tcp branch has been merged into the mainline already, so unless
you know of someone else who is deriving from it I see no real reason to
update that.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Ralph Lange
Re: FW: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Ralph Lange
<2010>
2025
2026
RE: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Jeff Hill
<2010>
2025
2026
