> which I think is a bug in CAC.
Actually, looking at the diffs (using windiff) it would appear that the issue was introduced by a conflict between the fix for Mantis 334 (revision 11805 of cac.cpp) and the TCP name resolver merge (revision 12092 of cac.cpp). Unfortunately, mantis 334 was fixed after the TCP name resolver upgrade was written. In particular, code in cac::transferChanToVirtCircuit was repackaged into the smaller cac::findOrCreateVirtCircuit and somehow this decisive line in cac::transferChanToVirtCircuit was discarded by the merge.
this->serverTable.add ( *pnewiiu );
this->circuitList.add ( *pnewiiu );
this->iiuExistenceCount++; <=========== omitted
pBHE->registerIIU ( guard, *pnewiiu );
Jeff
______________________________________________________
Jeffrey O. Hill Email [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Message content: TSPA
> -----Original Message-----
> From: Ralph Lange [mailto:[email protected]]
> Sent: Monday, August 16, 2010 10:03 AM
> To: Andrew Johnson
> Cc: Jeff Hill; EPICS Core Talk
> Subject: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp
> Hi Andrew,
> it looks as I have found the reason for the segfaults, which I think is
> a bug in CAC.
> In the cac::~cac() destructor, a private member
> "this->iiuExistenceCount" is used to determine if cac should wait for
> TCP threads to shutdown. While this counter gets correctly decreased in
> cac::destroyIIU(), it never gets increased or set (except initialized to
> 0 in the cpp constructor).
> So cac::~cac() was never waiting for the TCP threads to shutdown, and
> happily kept tearing down the timer/mutex infrastructure. If the threads
> were not fast enough, they were hitting on destroyed semaphores when
> cancelling their watchdog timers - that was causing the exceptions and
> segfaults.
> This one-line fix will take care of the problem:
> === modified file 'src/ca/cac.cpp'
> --- src/ca/cac.cpp 2010-04-15 21:06:16 +0000
> +++ src/ca/cac.cpp 2010-08-16 15:24:13 +0000
> @@ -287,6 +287,7 @@
> // shutdown all tcp circuits
> + this->iiuExistenceCount = this->circuitList.count();
> tsDLIter < tcpiiu > iter = this->circuitList.firstIter ();
> while ( iter.valid() ) {
> // this causes a clean shutdown to occur
> Maybe it actually takes care of several shutdown related issues...
> Yay!
> Ralph
- Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Ralph Lange
Re: FW: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Andrew Johnson
RE: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Jeff Hill
<2010>
2025
2026
Re: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Andrew Johnson
<2010>
2025
2026
