2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp
To: Jeff Hill <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Tue, 17 Aug 2010 12:07:37 -0400
 Hi Jeff,
thanks for the fix!
I'm not sure about that race condition, though.
In my fix:
Setting iiuExistenceCount to the circuitList.count() (line ~290) happens in the cac::~cac destructor while the lock is being held, immediately followed by calling unlinkAllChannels() on all circuits in that list.
The only place where the lock is given up is one block down (line ~307), when waiting for the tcp threads to exit.
What race condition are you seeing? I looked at the 11786 change and bug#541362. I perfectly see why a counter fixes the issue that appears when using a simple flag. But don't see where my fix would break the fixed behavior, as it is still using a countre, decrementing the iiuExistenceCount is still happening at the end of cac::destroyIIU(), and incrementing iiuExistenceCount (original fix) happens exactly when it is added to the list, so that (my fix) using circuitList.count() to set iiuExistenceCount yields the same result.
I'm perfectly fine with using the original (increment) fix, but I would like to understand where the difference is.
I think I also see another new race condition introduced by ca-over-tcp, which probably breaks the shutdown behavior for clients using ca-over-tcp, and needs to be fixed.
When the lock is given up in cac::~cac() and the loop (line ~307) waits for termination of all TCP tasks, an incoming name-res reply from a still active TCP circuit (the UDP task has exited by that time in the cac::~cac destructor) could open a new circuit (tcpiiu.c #2188), which would then be added to the circuitList (and iiuExistenceCount be incremented). For that new circuit, that the loop would be waiting for, unlinkAllChannels() is not being called, so it does not have a reason to terminate its threads.
Maybe we still need a flag: to avoid creating new circuits while the cac:~cac destructor runs?!
What do you think?
Thanks a lot,
Ralph
On 16.08.2010 19:46, Jeff Hill wrote:
+ this->iiuExistenceCount = this->circuitList.count();
Examining this change a bit closer I see that it will introduce a race condition when circuits are being created and destroyed at close to the same instant in time. See revision 11786 of cac.cpp which fixes mantis 334 if you are interested in what this code does. After running the regression tests, I pushed in a fix (which is removing above mentioned change and restoring the increment of iiuExistenceCount in cac::findOrCreateVirtCircuit.
Jeff
-----Original Message-----
Sent: Monday, August 16, 2010 10:03 AM
To: Andrew Johnson
Cc: Jeff Hill; EPICS Core Talk
Subject: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp
   Hi Andrew,
it looks as I have found the reason for the segfaults, which I think is
a bug in CAC.
In the cac::~cac() destructor, a private member
"this->iiuExistenceCount" is used to determine if cac should wait for
TCP threads to shutdown. While this counter gets correctly decreased in
cac::destroyIIU(), it never gets increased or set (except initialized to
0 in the cpp constructor).
So cac::~cac() was never waiting for the TCP threads to shutdown, and
happily kept tearing down the timer/mutex infrastructure. If the threads
were not fast enough, they were hitting on destroyed semaphores when
cancelling their watchdog timers - that was causing the exceptions and
segfaults.
This one-line fix will take care of the problem:
=== modified file 'src/ca/cac.cpp'
--- src/ca/cac.cpp      2010-04-15 21:06:16 +0000
+++ src/ca/cac.cpp      2010-08-16 15:24:13 +0000
@@ -287,6 +287,7 @@
               // shutdown all tcp circuits
               tsDLIter<  tcpiiu>  iter = this->circuitList.firstIter ();
               while ( iter.valid() ) {
                   // this causes a clean shutdown to occur
Maybe it actually takes care of several shutdown related issues...
Yay!
Ralph
RE: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Jeff Hill
Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Ralph Lange
Prev: RE: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Jeff Hill
Next: Bazaar commit messages: style guide Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Jeff Hill
