2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Bazaar commit messages: style guide
To: "EPICS core-talk" <[email protected]>
Date: Tue, 17 Aug 2010 11:27:55 -0500
In order to make Bazaar log messages readable in the future, I would ask all
committers to follow the style advice given below when writing commit messages
(some of these were new to me too).
- Andrew
Summary line and revision text
Bazaar, like all other modern VCS tools, uses the first line of the commit
message as the summary which appears in email Subject: lines, the --line
output to bzr log, etc. So a descriptive yet concise first line is important.
For really trivial fixes, that single line as patch name is sufficient; but
for more comprehensive patches please add a long comment (ie the subject line
plus some prose describing what you’re up to. It doesn’t have to be perfect.
Put a single blank line between your summary line and the paragraphs you write
as the main descriptive text of the revision comment.
Remember that years from now someone will do bzr log filename and all the
revisions which affected that one file will show. So if you can, try to keep
commits on-topic; you don’t have to mention every last little change but try
your best to summarize the impact on major files if they’re somewhat
tangential to the main thrust of the rest of the commit.
Max message width 70 characters!
Most text editors word wrap by default at the width of your terminal window,
often 80 characters. This becomes a problem when viewing commit messages
because VCS tools typically indent the message by a few whitespace characters,
and in some cases clip lines at the terminal width when viewing commit logs.
If you don't word wrap at all it looks even worse, and viewing the commit on
launchpad will result in an illegible very wide window.
Therefore, lines in commit messages must be word wrapped using hard returns at
70 characters.
Set your user id!
If you make a commit to a local branch before you've told Bazaar what your
name and email address is, it will make a guess and record that in the commit,
and from then on that user id will be forever associated with that commit when
it later gets merged into Base.  Use 'bzr whoami' or set the BZR_EMAIL
environment variable.
The best FOSS code is written to be read by other humans -- Harald Welte
Re: Bazaar commit messages: style guide Ralph Lange
Prev: Re: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Ralph Lange
Next: devLib extensions review and testing request Davidsaver, Michael
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: FW: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Andrew Johnson
Next: Re: Bazaar commit messages: style guide Ralph Lange
