2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp
To: Jeff Hill <[email protected]>
Cc: "'EPICS Core Talk'" <[email protected]>
Date: Wed, 18 Aug 2010 10:59:09 -0400
 On 17.08.2010 21:00, Jeff Hill wrote:
Looks like a potential issue.
option 1)
You might insert "this->chanTable.removeAll ()" after line 295 in ~cac
which will cause cac::transferChanToVirtCircuit to noop return at line
583. You would need to supply a temporary (auto) tsSLList<T>  target to
removeAll but could safely ignore
option 2)
Just add a bool flag to cac as you propose, set it just after line 295
in ~cac, and check it at the beginning of cac::transferChanToVirtCircuit.
It would also need to be initialized in the cac ctor. Of course the set
and test will need to be protected by a Guard. The downside is that
this requires slightly more memory at runtime, but this is no-doubt
insignificant. Perhaps the only downside is needing to remember the
purpose of yet another binary flag a few years down the road.
I'll go with the simple approach.
This is a one-way communication, so a proper set-and-test is not necessary.
I will set the flag (under the lock) at the beginning of the cac dtor and check it (under the lock) at the beginning of cac::transferChanToVirtCircuit - that should do it. I think a comment will reliably remove the need to remember the purpose of the flag. ;-)
Thanks for your help!
Ralph
Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Ralph Lange
RE: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Jeff Hill
Re: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Ralph Lange
Prev: Re: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Ralph Lange
Next: Re: Bazaar commit messages: style guide Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Jeff Hill
Next: Re: FW: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Ralph Lange
