2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Dynamic Loading and Unloading of EPICS Device Support and Record.
To: "Ernest L. Williams Jr." <[email protected]>
Cc: Core-Talk <[email protected]>, "Geng, Zheqiao" <[email protected]>
Date: Tue, 7 Sep 2010 15:44:17 -0500
Hi Ernest,
On Tuesday 07 September 2010 14:54:51 Ernest L. Williams Jr. wrote:
> What is the current project status of EPICS Dynamic Record loading?
> Is that only on the 3.15 trunk?
It's not even planned for implementation there at the moment, let alone
available.  The problem is that there are *no* locks for the data structures
that describe the currently loaded records, and any attempt to retro-fit them
will probably cause a major performance hit on the IOC runtime.
> As we embark upon uTCA here at SLAC; we will need that functionality.
Then you're going to need to allocate a lot of *talented* manpower to help us
implement it in version 3.x, or take a step back and re-think what you need to
do.
One possibility might be to write code that probes the crate and works out
what devices the IOC has to control, then generate the necessary .db file(s)
from that information.  At that point you can fire up the IOC, load those .db
files and start controlling stuff.  If you need to shut down just a part of an
active IOC without affecting the rest of it, you would regenerate the .db
files with the necessary devices removed and restart the IOC with the now
reduced .db files, then you're free to take out the relevant hardware without
it disturbing the IOC.  You might want to look into the DESY/KEK work on
redundant IOCs for making the restart as fast as possible.
Alternatively start looking at Marty Kraimer's Java IOC which I believe was
designed to allow dynamic record creation and deletion.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Re: Dynamic Loading and Unloading of EPICS Device Support and Record. Marty Kraimer
RE: Dynamic Loading and Unloading of EPICS Device Support and Record. Geng, Zheqiao
Dynamic Loading and Unloading of EPICS Device Support and Record. Ernest L. Williams Jr.
Prev: Dynamic Loading and Unloading of EPICS Device Support and Record. Ernest L. Williams Jr.
Next: Re: Dynamic Loading and Unloading of EPICS Device Support and Record. Marty Kraimer
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
