2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base
To: [email protected]
Date: Mon, 25 Oct 2010 12:02:45 -0000
In general I like the idea of named events. I have faced situations where I was lost about the used soft events in an IOC and it was tedious to track down what HW event fired what SW event to avoild clashes.
My comments:
1) As far as I understood the ordring of adding/removing scan lists is not affected. I think it is important that the position of the event nodes in the lists remains the same in both cases (event / named_event).
2) The new method has introduced an additional lock for each priority list (event_list_lock) and for accessing a node in the event list first the lock of the corresponding priority has be acquired, the priority list be found, and the lock is then released. This will also introduce some performance penalty (in addition to strcmp). In the current method this is achieved by means of 2-dimentional array of [priority][event].
I know that normally number of soft events in an IOC is not big, nevertheless I think one has to study the performance effects of the new appraoch more deeply.
https://code.launchpad.net/~dirk.zimoch/epics-base/named-soft-events/+merge/26190
Your team EPICS Core Developers is requested to review the proposed merge of lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base.
[Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Dirk Zimoch
Prev: Re: what was the time before 1990? Andrew Johnson
Next: Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Dirk Zimoch
