2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Error in creating the example application
To: xyz140406 <[email protected]>
Cc: [email protected]
Date: Thu, 28 Oct 2010 09:06:53 -0500
Try putting quotes around the EPICS_BASE value in your application configure/RELEASE file.
I think blank spaces around the # sign may be causing your problem.
Janet
xyz140406 wrote:
Hi,guys
I have just installed the base-3-14-11 on openSUSE10.0.And then i want to creat the example application,i fail and do not konw why.look for you help,thanks!
there are the codes below:
linux:/home/xy/EPICS # mkdir iocApps
linux:/home/xy/EPICS # cd iocApps
linux:/home/xy/EPICS/iocApps # /home/xy/EPICS/base-3-14-11/bin/linux-x86/makeBaseApp.pl -t example EXP
linux:/home/xy/EPICS/iocApps # /home/xy/EPICS/base-3-14-11/bin/linux-x86/makeBaseApp.pl -i -t example EXP
The following target architectures are available in base:
    linux-686
    linux-x86
What architecture do you want to use? linux-x86
The following applications are available:
    EXP
What application should the IOC(s) boot?
The default uses the IOC's name, even if not listed above.
Application name? EXP
linux:/home/xy/EPICS/iocApps # EPICS_HOST_ARCH=linux-x86 make
make -C ./configure install
make[1]: Entering directory `/home/xy/EPICS/iocApps/configure'
perl /home/xy/EPICS/base-3-14-11/bin/linux-x86/makeMakefile.pl O.linux-x86 ../..perl /home/xy/EPICS/base-3-14-11/bin/linux-x86/makeMakefile.pl O.linux-686 ../..mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86 install
make[2]: Entering directory `/home/xy/EPICS/iocApps/configure/O.linux-x86'
/home/xy/EPICS/base-3-14-11/configure/CONFIG_APP_INCLUDE:20: *** miss“endif”。 stop。
make[2]: Leaving directory `/home/xy/EPICS/iocApps/configure/O.linux-x86'
make[1]: *** [install.linux-x86] error 2
make[1]: Leaving directory `/home/xy/EPICS/iocApps/configure'
make: *** [configure.install] error 2
Error in creating the example application xyz140406
Prev: Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Dirk Zimoch
Next: Re: Error in creating the example application Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Error in creating the example application xyz140406
