Hi,guys
I have just installed the base-3-14-11 on openSUSE10.0.And then i want to creat the example application,i fail and do not konw why.look for you help,thanks!
there are the codes below:
linux:/home/xy/EPICS # mkdir iocApps linux:/home/xy/EPICS # cd iocApps linux:/home/xy/EPICS/iocApps # /home/xy/EPICS/base-3-14-11/bin/linux-x86/makeBaseApp.pl -t example EXP linux:/home/xy/EPICS/iocApps # /home/xy/EPICS/base-3-14-11/bin/linux-x86/makeBaseApp.pl -i -t example EXP The following target architectures are available in base: linux-686 linux-x86 What architecture do you want to use? linux-x86 The following applications are available: EXP What application should the IOC(s) boot? The default uses the IOC's name, even if not listed above. Application name? EXP linux:/home/xy/EPICS/iocApps # EPICS_HOST_ARCH=linux-x86 make make -C ./configure install make[1]: Entering directory `/home/xy/EPICS/iocApps/configure' perl /home/xy/EPICS/base-3-14-11/bin/linux-x86/makeMakefile.pl O.linux-x86 ../..perl /home/xy/EPICS/base-3-14-11/bin/linux-x86/makeMakefile.pl O.linux-686 ../..mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86 install make[2]: Entering directory `/home/xy/EPICS/iocApps/configure/O.linux-x86' /home/xy/EPICS/base-3-14-11/configure/CONFIG_APP_INCLUDE:20: *** miss“endif”。 stop。 make[2]: Leaving directory `/home/xy/EPICS/iocApps/configure/O.linux-x86' make[1]: *** [install.linux-x86] error 2 make[1]: Leaving directory `/home/xy/EPICS/iocApps/configure' make: *** [configure.install] error 2
| ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
