Subject: |
Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base |
"Ben F." <[email protected]> |
To: |
[email protected] |
Date: |
Wed, 27 Oct 2010 21:52:40 -0000 |
On Mittwoch, 27. Oktober 2010, Dirk Zimoch wrote:
> I tested long event names like "Event with a very long name number
> 123" (up to 38 chars, the first 35 of them the same for all 255
> events) named-soft-events
> 3.145 seconds
> named-soft-events2
> 2.381 seconds
> More or less the same as with short event names. (Numbers vary a bit
> from turn to turn)
Interesting. I'd have expected the ratio between the two versions to
increase for longer strings. I did some research and found that gcc
heavily optimises strcmp, resulting (on certain architectures) in
machine code that uses 16-byte instructions, see
http://stackoverflow.com/questions/1128096/c-string-comparison-in-one-clock-cycle
You learn a bit more every day...
Cheers
Ben
"Never confuse what is natural with what is habitual."
-- attributed to Mahatma Gandhi
https://code.launchpad.net/~dirk.zimoch/epics-base/named-soft-events/+merge/26190
Your team EPICS Core Developers is requested to review the proposed merge of lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base.
- Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Dirk Zimoch
Error in creating the example application xyz140406
<2010>
2025
2026
<2010>
2025
2026
