2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epicsEvent
To: [email protected]
Date: Fri, 29 Oct 2010 08:57:00 -0400
 On 28.10.2010 18:59, Ben Franksen wrote:
Regarding the choice of which task will get the semahore if more than
one is waiting, I will for now assume that this is (intentionally) left
unspecified. This means I will have to implement FIFO order on top of
epicsEvent. The only other solution would be to extend the interface
with another constructor and then implement FIFO order *inside*
epicsEvent for those systems that do not support that natively (which
is what you wrote above, so maybe you *did* get the point I was trying
to make and I didn't get yours. Whatever ;-).
My current idea is to wait for your FIFO implementation and then see if that can be moved into epicsEvent... ;-)
Ralph
Re: epicsEvent Ralph Lange
Re: epicsEvent Ben Franksen
Prev: RTEMS tests -- epicsThreadOnce broken? Eric Norum
Next: Re: RTEMS tests -- epicsThreadOnce broken? Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epicsEvent Ben Franksen
Next: Re: epicsEvent Eric Norum
