2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RTEMS tests -- epicsThreadOnce broken?
To: Eric Norum <[email protected]>
Cc: Core-Talk Talk <[email protected]>
Date: Fri, 29 Oct 2010 10:25:32 -0500
On Thursday 28 October 2010 19:00:26 Eric Norum wrote:
> While running the epicsEventTests I also ran the other tests on RTEMS --
> and got some disturbing results:
That is generally why I ask people to run tests on the -pre1 release...
> ***** epicsThreadOnceTest *****
> 1..11
> ok  1 - runCount = 8
> ok  2 - once-0: initCount = 1
> ok  3 - once-1: initCount = 1
> ok  4 - once-2: initCount = 1
> ok  5 - once-3: initCount = 1
> ok  6 - once-4: initCount = 1
> not ok  7 - doneCount = 4
> ok  8 - once-5: initCount = 1
> # init was run by once-0
> ok  9 - once-6: initCount = 1
> Recursive epicsThreadOnce() initialization
> ok 10 - once-7: initCount = 1
> Thread recurse (0xa01001b) can't proceed, suspending.
> ok 11 - Recursive epicsThreadOnce() detected
>     Results
>        Tests: 11
>       Passed:  10 = 90.91%
>       Failed:   1 =  9.09%
> Have the recent epicsThreadOnce changes broken something on RTEMS? (!!!)
Actually it doesn't look that bad, just that the test code isn't waiting long
enough for all the once-<n> threads to run; they are running later on, but by
then it's stopped counting.  Try increasing the delay immediately before the
testOk(doneCount==...) line.
This is the place where I really wanted a broadcast epicsEvent that would
start all the waiting threads at once, to test that the once really can't be
executed in parallel.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
Re: RTEMS tests -- epicsThreadOnce broken? Eric Norum
Re: epicsEvent Eric Norum
Prev: Re: epicsEvent Ralph Lange
Next: Re: RTEMS tests -- epicsThreadOnce broken? Eric Norum
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RTEMS tests -- epicsThreadOnce broken? Eric Norum
