2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RTEMS tests -- epicsThreadOnce broken?
Cc: Core-Talk Talk <[email protected]>
Date: Fri, 29 Oct 2010 08:38:15 -0700
On Oct 29, 2010, at 8:25 AM, Andrew Johnson wrote:
> Actually it doesn't look that bad, just that the test code isn't waiting long
> enough for all the once-<n> threads to run; they are running later on, but by
> then it's stopped counting.  Try increasing the delay immediately before the
> testOk(doneCount==...) line.
> This is the place where I really wanted a broadcast epicsEvent that would
> start all the waiting threads at once, to test that the once really can't be
> executed in parallel.
For strict priority-based systems would it not be possible to get this effect by starting all the threads at a lower priority than the main thread -- then when the main thread pauses all the others get to fight for the CPU?
Eric Norum
[email protected]
Re: RTEMS tests -- epicsThreadOnce broken? Andrew Johnson
Re: epicsEvent Eric Norum
RTEMS tests -- epicsThreadOnce broken? Eric Norum
Prev: Re: RTEMS tests -- epicsThreadOnce broken? Andrew Johnson
Next: Re: RTEMS tests -- epicsThreadOnce broken? Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
