On Friday 29 October 2010 10:38:15 Eric Norum wrote:
> On Oct 29, 2010, at 8:25 AM, Andrew Johnson wrote:
> > Actually it doesn't look that bad, just that the test code isn't waiting
> > long enough for all the once-<n> threads to run; they are running later
> > on, but by then it's stopped counting. Try increasing the delay
> > immediately before the testOk(doneCount==...) line.
> > This is the place where I really wanted a broadcast epicsEvent that would
> > start all the waiting threads at once, to test that the once really can't
> > be executed in parallel.
> For strict priority-based systems would it not be possible to get this
> effect by starting all the threads at a lower priority than the main thread
> -- then when the main thread pauses all the others get to fight for the
> CPU?
That might help, you could try temporarily adjusting the priority of the main
thread around the epicsThreadSignal() .. epicsThreadSleep() calls. I was
going to look at adding another signal that the last onceThread() would
release, so the main thread doesn't have to use sleep (this speeds up the
test).
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it. If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence. -- Bertrand Russell
- Re: RTEMS tests -- epicsThreadOnce broken? Andrew Johnson
- Re: RTEMS tests -- epicsThreadOnce broken? Eric Norum
<2010>
2025
2026
<2010>
2025
2026
